Brodit proclip mount for C5
steve101
I have had a look at the various proclip mounts available from Brodit http://www.brodit.com/ for my tomtom satnav. Has anyone fitted one of these to a C5 and which location would you advise?
- x 5674
Personally I'd bodge it for a while to find the ideal location before purchase in case the Brodit clip is unable to fit where you want it.
Due to the heat reflective screen C5s have problems with after market satnav units. The only location for theb is the 'dotted' area around the screen mirror as this is provide to allow RFID toll responders. Unfortunately the won't stick, due to the dots
Having said that I used my daughter's Tomtom a couple of weeks ago and ended up with it stuck to the top of the screen, far right. Not the ideal location by any means but the only place I could actually see it.
Try bluetacking it in various locations, see if you get a signal.
Homer
- x 16
steve101
Xaccers
- x 188
Spooky! I was just talking to Jim about these mounts today!
Have you found a UK retailer?
DIY sphere tool
DIY sphere tool
steve101
I used http://www.morpethmobiles.co.uk/brodit_holder.asp last time. They were the cheapest and good delivery times. That was over a year ago so might be different now.
- x 5674
Yes, the perceived wisdom is that the screen stops them working but it may just be certain models.Homer wrote:I have no problems using GPS in my 807 with reflective screen.
I have a Brodit mount for my N95, on the 807 it fits nicely on the centre vents.
I tried all over the place and in the end just stuck it to the screen (instead of trying it there first to prove/disprove popular theory) Worked fine.
Xaccers
- x 188
older ones had the screen probems.
DIY sphere tool
DIY sphere tool
Homer
- x 16
I believe that's where I got mine from as well.steve101 wrote:I used http://www.morpethmobiles.co.uk/brodit_holder.asp last time. They were the cheapest and good delivery times. That was over a year ago so might be different now.
f00lzz
I have an old Navman 530 and I have used it in loads of cars including a C5 and it has never had a problem in obtaining a Sat. fix.
IMO Brodit clips are best.. remember, if you need reading glasses you don't want to have the satnav positioned so you have to keep putting your glasses on or to far away that you can't see it.
Ian
Ian
Ian
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
2001 Xantia 3.0 Exclusive
1999 Xantia 1.9TD
1997 Xantia 3.0 Exclusive
1995 XM 3.0 Exclusive Estate
Account Ref: 6419
Current Cars
Nissan X-Trail SVE
Saab 2.2TiD
Merc E270 Estate
Past Citroens
1999 Xantia 1.9TD
