What happens if ...........
HDI
- x 7
the aircon system has been left without gas for 3 years or so and is then recharged ? Will anything have suffered or been damaged ?
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
davetherave
- x 4
HDI
- x 7
I think the system was left discharged after a suspected engine change.
I have not used it since realising it was empty.
Thanks for the tip about Kwik Fit , I'll drop over tomorrow.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
davetherave
- x 4
DickieG
- Monaco's youngest playboy
- x 38
davetherave
- x 4
HDI
- x 7
AC is something I don't know much about. Is the drier the cylinder with the inspection window at the top ?
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
davetherave
- x 4
davetherave
- x 4
I believe this is where I got mine from
http://www.autoairconparts.co.uk/receiv ... -1129.html
Not a bad price!
Not a bad price!
(95) XM Silver 2.1td Exclusive.
(87) Cx 2.5 DTR T1 undergoing major cosmetic surgery.
GPZ500s
GPZ500s
HDI
- x 7
- x 1939
Could someone explain why it is deemed necessary to replace the drier if the A/C system is emptied for whatever reason? Surely the replacement willl be just as likely to have atmospheric moisture in - or am I missing something?
Does this apply to every vehicle with A/C such as my Xsara and C5?
davetherave
- x 4
I believe that over time the dryer loses the ability to absorb moisture so well, so perhaps the system would be fine without a change, but any moisture is dangerous so as it is relatively inexpensive its worth doing!
To my knowledge it would apply to any system any car. (saying that my knowledge is limited)
GPZ500s
GPZ500s
xmexclusive
Hi All
New aircon rads and dryers etc are supplied under vacuum with plugs on the connections to keep moisture out of the system until you are ready to couple up and charge with gas. A dryer is a one way process to mop up small amounts of residual moisture from the system. If left open to the atmosphere for a period of time then it will have used up much if not all of its drying capability.
John
John
Xmexclusive
- x 1939
Now that makes a lot of sense. Any idea what the drying agent is? If it's silica gel (like in the dessicating jar in the school labs of old) then surely it can be regenerated in an oven. If it's a chemically reactive agent then it probably can't.xmexclusive wrote:A dryer is a one way process to mop up small amounts of residual moisture from the system. If left open to the atmosphere for a period of time then it will have used up much if not all of its drying capability.
xmexclusive
Never sectioned one but rumor has it that the dryer contains silica gel and when it gets saturated the containing bag bursts and the resultant mess gets spread all round the system. This then overloads the compressor and burns it out. Chances are the system is then inadequately flushed and the residual debris slowly works round the system then takes out the replacement compressor the day after the warranty ends. All crap spread by aircon specialist to fleece you or is it?
John
John
Xmexclusive
