When I rev up my 1360 diesel, the revs are slow to return to idling speed, as if you were releasing the accelerator pedal slowly.
The cable appears free and has a small amount of slack,but I do not know what else to check.
Suggestions appreciated. Thanks.
106 diesel idling
- x 1060
woodhead722
Dave Burns
- x 3
There could be two such dampers involved and both fixed to the pump.
On a Bosch pump as fitted to the td xantia there is the famousely useless damper on the front of the pump, which operates through the entire range of the accelerator lever.
Then there is a small squat damper about 40mm dia. at the back of the pump, this one only operates during the last few millimeters of accelerator lever travel.
Get out with the spanners if they are present, and wang'em down the garden[:D]
Dave
Dave
woodhead722
mbunting
