craig
Xantia heater blower fault
craigo
Hi folks
just joined this site lots of great advice hoping to get some help with my 2000 xantia 2.0 hdi 110 bhp estate. I,m having problems with my heater blower and air-con not working until car reaches operating temprature then works as normal also one of the main cooling fans is constantly switching on and off . Any help would be greatly appreciated.
craig
craig
davetherave
- x 4
Welcome to the forum!
Try using the search function at the top of the page to find information on heater blowers and air con, there is a lot of info and links, but if you have a trawl through you should be able to narrow down what your problem is then post back!
I found all the info very usefull in fixing my air con!
(95) XM Silver 2.1td Exclusive.
(87) Cx 2.5 DTR T1 undergoing major cosmetic surgery.
GPZ500s
GPZ500s
citroenxm
- Fallen Hero
- x 70
Just want to add, theres only ONE temp sensor on HDi 8v engines that the ECU refers to for controlling the Cooling fans ETC...
Its on the side of the thermostat house, below the intercooler to inlet manifold pipe..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
craigo
Thanks paulcitroenxm wrote:Just want to add, theres only ONE temp sensor on HDi 8v engines that the ECU refers to for controlling the Cooling fans ETC...
Paul
