Activas and Safety
KP
x 27
Activas and Safety
Unread post by KP »
We've all seen the adverts for the activas, BUT are Activa's actually safer round corners, under braking in corners.... than other normal sprung cars and other normal Xantias/C5's?
Not on about crash tests but more about the grip and the control of the car under these circumstances...
Citroenmad
x 110
Unread post by Citroenmad »
Id certainly say they should be, as their body roll is controlled. Make a dramatic lane change at motorway speeds in a normal car and it will probably lose control, an Activa id expect to be better and remain stable.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
Sl4yer
Unread post by Sl4yer »
Yes, I reckon they should be, with a couple of provisos:
1. All hydraulic systems are working correctly;
2. The tyres are good quality and condition, and correctly inflated.
All the trick suspension in the world will do you no good if the bits that contact the road aren't up to it.
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
xmexclusive
Unread post by xmexclusive »
There is no way that Activas or any Citroen with hydraulic suspension will be safer than other cars round bends unless you have a crap car with normal suspension in front to slow you down. Better comfort and more controlled grip transfer just allows faster curving for the same level of safety.
John
Xmexclusive
Xaccers
x 186
Unread post by Xaccers »
There's a video on youtube that shows cars slaloming through cones and basically spinning off after losing control as the resonance builds and they swing wilder and wilder.
Then they show, I believe an XM, with hydractive suspension and it's able to do the slalom at higher speed without trouble.
Here it is:
And who could forget:
DIY sphere tool
addo
Sara Watson's Stalker
x 95
Unread post by addo »
I honestly believe that at the margin of control, hydraulic Citroëns are slightly more predictable and manageable than a steel sprung car. There's less tyre "chatter" - for want of a better word, and more skidding with better contact. You can do it all wrong; go hard into a corner and hit the anchors ferociously mid-steer. It just slows down until directional control returns.
On a dry, near-flat corner, I reckon the Activa would be slightly faster than a non-active suspended citroën.
citrov6
Unread post by citrov6 »
i would think the activa being more stable with its weight transfer would be more predictable and manageable in those conditions. any other car would just alert you sooner with under steer, which many car manufacturers see as 'safer' in those conditions because the driver is alerted to the situation. where as a professional driver would read the situation before this happens. so in the context of ordinary drivers like us the context of safe would be something like that to begin with.
i agree with addo hydraulics are far much more predictable than steel springs, steel just doesn't react as fast or linearly, in a salalom situation i would think steel would become unstable faster
Love my black v6 xant - only one with cream coloured leather too!
xmexclusive
Hi All
The salalom is a special case which acentuates the feature that steel springs repeatedly loaded/unloaded fast enough can reach a critical resonant frequency where motion is amplified instead of damped. The result is a tangential slide if the grip fails or a roll if the grip holds.
As I understand it if you fit an XM with a very large orifice sphere on one side at the front it will fail the salalom in exactly the same way as the steel sprung car does.
The reason that hydaulically suspended cars can curve at higher speeds is simply that they adjust weight loading faster and better than conventional cars. The hydraulic system working properly makes sure that the contact patch size and position remains better distributed between the four wheels.
John
Xmexclusive
andmcit
x 30
Unread post by andmcit »
Citroën wrote:A revolutionary driving experience
When it comes to taking bends, even the best high performance saloons come
nowhere near the new Xantia Activa. For a safer and more comfortable ride,
it has no equal
Citroën's view on safety!
Andrew
