broken s2 lumbar support
citrov6
Unread post by citrov6 »
on the drivers side of the black v6 the lumbar has been broke since i got it, and i wonder if it is an easy fix, or does it need the whole seat stripping, and whats the price like of the support
Love my black v6 xant - only one with cream coloured leather too!
andmcit
x 30
Unread post by andmcit »
Isn't the pocket of the support bag filled and emptied by air with these?
Andrew
x 8406
andmcit wrote:Isn't the pocket of the support bag filled and emptied by air with these?
Yes, it is. Can you hear the compressor running when you operate the switch.
Also, is it both upper and lower supports not blowing up or just teh one?
Under the seat you'll see the compressor and piping and behind the control panel the wiring.
citrov6
now that you mention it, nothing pumps up, and the more i think about it i don't think i heard the compressor going, so maybe it is the compressor or an electrical fault.
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Its more than likely down to a faulty switch, pull off the three switch levers and reach behind the switch assembly to push the lot out for full examination. The switches are available separately as well as the switch levers. Inside the switches are a few springs which can become dislodged.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
citrov6
ah it is loose, hopefully that is it, thanks DickieG i will check that
