Xantia 1.9Td Gearbox Oil Change
jmd
Any views on renewing the Transmission (Gearbox) Oil on the Xantia 1.9Td,after having covered 160,000Mls.I'm told it is not necessary,although the oil has been there since new it looks fine,but common sense "sort of" dictates that all oil should be renewed after a certain life span.
JohnD
- x 72
Dave Burns
Gearbox oil isn't subjected to anything like the harsh operating conditions that engine oil has to cope with, plus it doesn't get contaminants mixed in with it during its life span.
There will be some metalic particles in it but this mostly drops out of suspension during periods of inactivity, and even if you do drain it you wont get that out because its sat at the bottom of the box.
You may have to change the oil for other reasons, such as to replace worn diff seals, driveshafts or to replace a clutch, all of which require the oil to be drained, of course if the car has allready had a clutch replaced it will not be running in the original oil anyway.
Dave
Dave
jmd
