Xantia- Oil in water
reblack68
Unread post by reblack68 »
Is there anything other than the head gasket that can allow the engine oil to enter the coolant?
There is no water in the oil, just oil in the water. The hoses to the oil filter have been bypassed and there was no evidence of oil down there. The car is running perfectly well, temperature and exhaust are normal, it's just putting oil into the coolant.
The car is a 1997 Xantia 1.9TD.
Any ideas?
Richard
Care of a 1994 205 D.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
CAN NOT be the turbo either, XUD Turbo D units are that efficient the coolant DOES NOT run through the turbo to cool it, unlike the petrol engine sisters,
So it can ONLY be the head gasket! Not necesserally on a bore, but possibly between a water and oil way in the gasket??
Paul
A very sad...
1994 XM 2.1 d auto
x 1240
Unread post by Peter.N. »
..or it could be a crack, either in the block or head - had the same problem with an XM. I used to periodically slowly overfill the header tank which allowed the oil to float off and out, ran it for miles like that.
citroenxm
Fallen Hero
x 70
Couldn't really see an XUd Block crack, dry liner cast is one of the hardest - BUT I guess theres a first for anything, Ive never seen a failed XUD block, but head could well be the problem..
As Ive said, you've ruled out the only culprait, disconnecting the oil cooler pipes, which we would have all said have been your problem.. with that out of the equation, then it HAS to be HEAD OFF job :-(
Sorry, can not be anything else.
Paul
A very sad...
1994 XM 2.1 d auto
x 1240
Hi Paul
This was a Mk1, changed the head gasket, bypassed the oil cooler, made no difference, but must admit its the only one I have heard of. Probably the head then.
hobblerian
Unread post by hobblerian »
I'm with Peter N, my 2.1SD had the same fault. Flaw in the engine casting, it gradually formed white/creamy emulsified gunk in the expansion tank. Ran it like that for 1000's of miles though.
Previous 90H S1 XM 2.1td SD Manual
Current 97P S2 XM 2.1td VSX Manual
reblack68
Ah. This isn't gradual though. :(
If it's all the same I'll wait for somebody to tell me it isn't the head gasket. :lol:
Richard
KP
x 27
Unread post by KP »
Could it no be the oil/water cooler that sits on the oil filter mounting thingy(technical term)??
citroenxm
Fallen Hero
x 70
Nope, he HAS already disconnected it... hence it being nothing else but between the two blocks of metal :lol:
Paul
A very sad...
1994 XM 2.1 d auto
Xantidote
x 4
Unread post by Xantidote »
Richard,
Could this problem oil leak be what Fred1 referred to recently in reply to a posting by Vince, regarding oil leaking around crankshaft pulley area?
Fred1 was referring to problem on early Xantias, where the oil feed passing through the head gasket found it's way into coolant system. Not sure if yours considered an early car in this context. Has your car had new head gasket at some stage, perhaps gasket of questionable quality?
Martin
Martin
1995 Xantia TDLX (deceased :( )
KP
x 27
Unread post by KP »
my bad for not reading it all :)
citroenxm
Fallen Hero
x 70
I may be sticking my neck out a bit, but aside from Gasket Quality, and fuel system upgrades etc, I dont think the XUD EVER changed design what so ever and remaind the same right through production INTERNALLY...
Its the Gasket - HAS to be! Or the head itself...
Paul
A very sad...
1994 XM 2.1 d auto
x 8391
citroenxm wrote: I dont think the XUD EVER changed design what so ever and remaind the same right through production INTERNALLY...
Yes, it stayed pretty static Paul, there were small detail changes like the exhaust ports changing from square to round and valve sizes upped a bit but fundamentally, the earliest XUDs fitted to the Talbot Horizon is very, very similar to the last ones made.
After all, how can one improve diesel perfection in an engine designed by Ricardo?
The thing about the XUD is that it's not French at all; it's British :D This is in part given away by finding some items in it were designed using imperial measures. The valve shims are one such. Put a metrioc micrometer on them and they're nominally the size. Measure them with an imperial micrometer and the truth emerges!!!!
reblack68
Still waiting for somebody to tell me it's a rubber seal that costs 79p and takes 2 minutes to fit. :(
Richard
citroenxm
Fallen Hero
x 70
Sorry VERY SORRY Richard, they wont, because it wont be... :-(
I keep a stock of XUD's and useually, the Very delicate head gasket needs changing first..
Paul
A very sad...
1994 XM 2.1 d auto
