Berlingo Van Which Wheels?
nickmurphy
Unread post by nickmurphy »
Decided to look for some alloys for my berlingo van, it's a 2003 facelift model and at the moment it has the standard steels with 175s on it, anybody know which wheels are a straight swap? only looking for simple stuff like off a 206 or the like, just don't know what size i can go to or if i need special bolts, anyone done it?
cheers in advance
nickmurphy
back to the top
Citroenmad
x 110
Unread post by Citroenmad »
I think most things will fit from the smaller Citroen range, im sure ive seen them with the 14" Saxo VTR alloys on, they must be cheap on ebay now.
I cant remember if the 206 has the same wheel fitment as the saxo, if so there are some nice wheels.
I have the 15" 'Sirocco' style wheels on my 206 which i do like, 195 tyres should fit in the rear arches of a Berlingo?
Also i think range topping Berlings came with the Xsara Picasso wheels from new, so they are probably an option too. Which means most Xsara alloys should be ok too, although im not 100% sure.
Check around on ebay, but find out your required offset and stud pattern before hand.
You will need new wheel bolts, as most alloys require special bolts. They are around £1-£2 each from the dealers usually.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
Ross_K
x 110
Unread post by Ross_K »
Saxo 'Toulouse' alloys fit, as do the four spoke ZX Volcane ones
nickmurphy
thanks for the advice, i'll get looking!
Citroenmad
x 110
Not bad for a little over £10 with 4 hours to go!
http://cgi.ebay.co.uk/Citroen-xsara-sax ... 286.c0.m14
Should fit i would think, being Xsara wheels, but not 100% sure on that. You would need the bolts though.
Saxo VTR wheels:
http://cgi.ebay.co.uk/CITROEN-PEUGEOT-S ... 286.c0.m14
Saxo VTS:
http://cgi.ebay.co.uk/CITROEN-SAXO-VTS- ... 286.c0.m14
One thing you might want to think about is tyres, if your van carries a lot of weight you might need to upgrade to higher spec reinforded connercial tyres. As you ideally need the right spec for your van.
03 Seat Arosa 1.0S
Ross_K
x 110
Citroenmad wrote:One thing you might want to think about is tyres, if your van carries a lot of weight you might need to upgrade to higher spec reinforded connercial tyres. As you ideally need the right spec for your van.
Good point. My van failed its last DOE (equivalent of the MOT) for having tyres with the wrong load rating on, ie. car tyres.
dieseldoggy
Unread post by dieseldoggy »
Hi they all fit if 4 stud zx/zanty/xsara/peugoet/even fords but they wont fit on has bore is smaller than psa fittings thats the hole in middle. but they are all 4x108 which is the measurement between studs/bolts. you could go upto 15"+ just need to work out ratio/sizing.has if you go to big you could end up having to go to wide.and vans normally suffer in the rear arches for width ie inside floor side.but you should be able to find plenty cheap. steel wheels use diff bolts to alloys esp if older psa ones has they had flat seats in bolt holes and later used tapered bolts.
plus if you don't have an alloy spare remember to carry 4 bolts to fit spare wheel!
uniroyal do a 580 xl tyre which has a higher load rating
xantia 19td estate 96-7
nickmurphy
well that's interesting to know, load rating isn't an issue to me as the van is my wifes daily runabout and the heaviest thing she carries is some shopping and a wet dog!
thanks for all the help
Ross_K
x 110
It wasn't an issue for me either, but the MOT tester thought differently... :D
vince
x 13
Unread post by vince »
You know what, i have a thing for Berlingo steel wheels with the small black centre caps adorned with chevron logos.... When they are clean I think they look awesome 8)
That said im very much into OE spec clean vehicles :wink:
Keep the steels :P
nickmurphy
to be honest my wife can't understand why i want to change them, ours is a very original van, poverty engine 225k and totally unfaultable, even the leccy windows and remote locking work ok. i spose i'm just bored and want to mess around with it!
KP
x 27
Unread post by KP »
Vince is the OE King from what i can see :D
