been meaning to get a spare for a while, only having one set it is looking very worn.
would it be best to go to the dealers, i can imagine them charging a couple hundred for the priveledge.
where as i am also guessing a blank could be cut by a local keycutter and the imobiliser coded with lexia or some other method?
best place to get spare keys made?
citrov6
Love my black v6 xant - only one with cream coloured leather too!
Ross_K
- x 110
For a Xantia key, can't you just swap the blade and avoid reprogramming - any locksmith or shoe repair place should be able to do that unless the old blade is seriously worn? They might even be able to cut a new blade without seeing the old one if you have the key code on that little plastic card.
I would have thought you would only need a lexia if you were creating a whole new key...
citrov6
andmcit
- x 30
As you say the key is worn it'd be pointless cloning the worn profile onto a
new key from a ketcutters where the blank and cutting will likely cost as
much a Citroen will charge for a pukka new one!
I'v just been to the local Cit agent about my non starting v6 Xantia and
asked about a key for another car I've mislaid the key for. If you have the
code from the original maintenance handbook pack they new key cut will
cost about 6 to 7quid. If you don't have the number for a key there needs
to be a search with an intermediary Agent to Citroen to pull the right code
from a database which will cost around 15 so a key this method will cost
around 23ish quid.
Andrew
around 23ish quid.
Andrew
citrov6
JohnD
- x 72
My C5 came with two plips plus a key which would just unlock the doors - And start the alarm if the car had been locked with the plip. The key wouldn't start the engine. SWMBO lost that key and I also had one plip stolen. (My caravan was broken into in Spain) I was always a bit worried about just having the one plip.
My local dealer quoted me £146(inc vat) for a new one. I rejected that. Instead I got a key cut which unlocked the doors for 12Euros in Spain. Next I bought on ebay for £12 a C5 plip which was identical to mine but wrong blade. I removed the blade from the plip and replaced it with the recently cut blade. I asked Citroen if they could reprogramme the plib to my car. They tried unsuccessfully. I then gave this guy a ring:- http://www.theautolocksmith.co.uk/trans ... mming.html
He came to me within a couple of hours. He confirmed that the plip couldn't be programmed to the car. Apparently the chip was locked. He removed it and replaced it with another. He programmed that to the car so now I have a new plip which will unlock the car and start the engine. It won't auto-lock and it won't set the alarm - unless you do it with the key. It took him about 75 minutes and cost me £85.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
- x 94
citrov6
- x 1056
