Hi
My 2007 C5 has started "hunting" when on a light throttle or under load (say going up-hill) - this problem seems to come and go - the dealer says he has never heard of the problem but I have a vague recollection of seeing a topic that suggested it might be a dirty air-flow meter. Unfortunatly, despite spending 2 hours trawling through the forum I can't find anything relating to this issue - does anybody have any experience of this problem?
TIA
C5 2.0 HDI VTR Hesitation or Hunting
- x 5672
Welcome to the forum Delta Wizard.
There are a plethora of things that might cause the hunting, the MAF being a primary candidate.
Try spraying it a few times with carburettor cleaner and see if that helps.
Be very careful with it though, it is very sensitive to mechanical damage.
It should come out of the hose but I was too chicken, convinced that I would bust the clips holding it in and cause even more problems. It is easy enough to loosen the hose though.
click for larger images
Where are you located?
Delta Wizard
