Hi ,
The heater blower on my 1995 Z.X. , only works on one setting . [ number 3 . ]
I believe it"s the resistor pack ?
My question is ;
Do I need to take out the dashboard ?
Regards
Terry .
Faulty Resistor Pack
uncle buck
- x 10
Yeah it will more than likely be the thermal fuse in the resistor pack, you can replace this or just replace the whole pack.
You get to the resistor pack from under the bonnet.
You need to remove the wiper arm then the plastic trim that attaches under the windscreen, then you remove the plastic cover from the heater air intake and you can then get to the resistor pack, twist it anti clockwise to release it from the bracket.
Cheers.
Cheers.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
