I bought my Xsara a year ago. It's a 52 plate with only 41k miles. It had 28k when I got it. From day one I realised it was running a bit sluggish compared to my other car a VW Polo Estate TDI 90. I carried on until a few months ago when the engine management light came on one day and then got it diagnosed. Up came code P0235- boost pressure sensor signal too high. This was reset but defaulted soon afterwards. When run like this the car pinks at low revs in the first three gears and there is a flat spot just off idle. The car also lacks torque and slows up long hills.
I've been back again for a further diagnosis and this time a different code was found P0246 - Pressure converter: boost pressure control deviation.
We then did a road test and the engine management light came on - car resorted to full limp home mode and a repeat of the code 0235 - boost pressure sensor signal too high. Faults reset and the car drove superbly until -- next morning when it was back to square one. The Bosch man is consulting with Bosch on this and he thinks it might be the boost sensor but from the live data he has recorded it's more likely, he thinks to be a faulty boost control regulator or the turbo itself. In other words he doesn't know!!
Poke and hope seems the only fix on offer so we are going to fit a new boost sensor on Friday to see if that works. Another garage I spoke to today suggested a blocked EGR valve may be the cause of the problem.
Has anyone got any bright ideas? or maybe experienced the same problem and knows what the cure is? I'd be very grateful for any help.
