VEGGIE OIL OR SIMILAR IN A C5???
chris050
Folks
I had a previous query with my new (to me) C5. The feedback I got was fantastic and I thought I'd run this one by you all. Maybe I shouldn't tinker with this subject but just thought I'd ask....
I have a 2002 C5 2.0 HDi 110 Manual
I do get very good MPG, averaging 47-48mpg but I was wondering if these engines are capable of running on a "cheaper" fuel like veggie oil or bio-diesel. Has anyone tried it? Am I likely to knacker the car if I try it myself? Is it an absolute no-no or can it be done without modification?
As always, the advice I get will be heeded!! lol
Trainman
- (Donor 2018)
- x 43
Hi Chris, I can only speak for myself here, I spoke to Citroen about using Biodiesel in 2.2 HDi I had, they told me in no uncertain terms that (a) it would void the warrenty (b) It could cause a considerable amount of damage.
hence gave it up as a bad idea, but i could be wrong..........
Steve
http://c6owners.org/index.php
chris050
red_dwarfers
- x 58
I would have thought a twin tank setup where the properly refined veggie oil was brought into play once the engine had reached a certain temperature and was switched back to diesel a good few miles before the end of the journey to flush out all the veggie oil from the injection pump. This would only work on longer journeys what with the HDIs being such effiecent lumps. Im no expert mind.
The old 1.9 Bosch injected TD will run on anything that feels oily or so it seems
Kev
'19 C4 Cactus 130 Flair
- x 5672
No!
Veg oil in an HDI will ruin it
It doesn't vapourise like diesel and doesn't burn completely. The residue coats the cylinder walls and gums up the rings and valves.
Only the older engines with a pre chamber can burn svo properly.
I have run mine for a while on properly converted biodiesel. First from wvo then from straight rapeseed oil. It was no different than standard diesel in performance or economy (mine is rubbish anyway) but the exhaust smelled better than standard diesel.
KP
- x 27
Bio-Diesel should be fine in any modern diesel car, at least 5% of what you put in from a normal pump now has to be bio anyway
For cars that have run on normal diesel for a long time there are some pitfalls...
- It will clean the fuel system out very well so be prepared after about 500miles or less to get your fuel filter changed after running on 100% bio.
- mix it in portions, so on a C5 that would be about 10 litres for the first 2-3 tanks and if its ok move upto 20 litres of bio per tank and so on and so forth.
If any misfiring or loss of performance develops go straight back to dino diesel.
- In winter most people mix anyway unless they make their own bio and winterize it. this can easily be done by putting in at least 10litres of a performance diesel to every tank full of bio thins it down enough for the cold to stop it trying to wax over.
- Dont forget to boot you car every now and again even on normal diesel as it will help clear the cobwebs off as it were, and is good on bio as it helps burn things off a little bit more than dino diesel.
Xaccers
- x 188
Most manufacturers I've heard about do not warranty any more than 5-10% biodiesel in their engines either.
Personally, I would use nothing but proper diesel in a direct injection car.
If you want to use biodiesel or veg, then you'll just have to sell up and buy a better car, like the Xantia 1.9TD
DIY sphere tool
DIY sphere tool
cachaciero
- x 9
JohnD
- x 72
falling-out-with-my-car
- x 25
NO Not veggie but bio diesel yes but only use B30 blend which is recommended for use in citroen HDi's by citroen.
Last edited by falling-out-with-my-car on 27 Aug 2009, 15:26, edited 1 time in total.
chris050
Hello all
I think the general consensus here is that it isn't worth talking the risk. I'm not really interested in getting twin tanks or making any alterations to the car so I reckon the best thing to do is leave it as it is. Like I said, my economy is actually very good so rather than ruin what I think is a really nice driving car I'll suffer Alistair Darling's taxes!!
Again, many thanks for your views.
- x 25
whilst we are on this subject is it possible to down grade an HDi diesel engine so it will be happy on clean new veggie oil ie fit an older bosch pump and change the injectors?
just a thought for the future.
have just found this www.businesscar.co.uk/story.asp?storycode=2126
hope the link works but it says that citroen has ok'd a blend of Biodiesel ie B30 for use in all their HDi engines. if in doubt ring the main dealership they should know.
hope it helps.
regards Nigel.
hope it helps.
regards Nigel.
cachaciero
- x 9
Hdi to Bosch is not on, the Hdi is a direct injection engine, engines that use the Bosch e.g XUD are indirect injection and use a completely different head design to achieve this.falling-out-with-my-car wrote:whilst we are on this subject is it possible to down grade an HDi diesel engine so it will be happy on clean new veggie oil ie fit an older bosch pump and change the injectors?
hope it helps.
regards Nigel.
cachaciero
john alexander
- x 25
So \citroen are giving out the wrong information Then?
