GSA engine photos wanted
scratcher
x 3
Unread post by scratcher »
GSA Special.
I took my recently aquired(April) my GSA 1300, there were many oil leaks on the engine so I have had to renew oil seals which meant taking a lot of the engine apart. On putting it back together I realise my memorary is not as good as it used to be( it is 29 years since I had a GS engine apart). Does anyone have photos of the top areas of a GS engine they could post on the net, its the sundry brackets I am interested in. Gerry
Xantia vsx
GSA 1300
Previous AMI8 estate
GS1015
GSA1300 estate
BX16
BX17d
BX19destate
BX19d
hawkeye
Unread post by hawkeye »
Have you got a Haynes manual, as that has shots of the engine. I'm sure there's one somewhere in my loft - PM me, or ring 01453 844679, if you need it.
andmcit
x 30
Unread post by andmcit »
Hi Gerry,
I'm sure I can find you some pictures! Are there not any showing the
tinware and the HT leads in one or two of Citroen's own brochures
- try a Google.
Those yellowed grimy legs that are held on with 8mm bolts clip the joints of
the tinware and are meant just to hold the HT lead away from the metal engine.
I don't expect there'd be more than the outboard sides where the longest lead
runs to teh front cylinders.
I'll try and get back with something asap.
BTW, G's are totally AWESOME - the best car EVER!!! 8)
Andrew
uncle buck
x 10
Unread post by uncle buck »
Any of the pictures >> HERE << any use.
HTH.
Cheers.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
x 5674
There are a few Youtube clips that could possibly show you the parts you are looking for.
There is this too :shock:
scratcher
x 3
GSA engine photos
Hi all, thanks for all your replies. I can see most of the details if I enlarge the pictures you all kindly sent. Ihave the Haynes manual and a disc of the Citroem manual. So with all the information I should be able to complete the task and get the car back on the road. I wanted a car with the Citroen suspension but without the computer electronics that my Xantia has, something I can easily service during the rest of my retirement. Thanks again everybody. Gerry
Xantia vsx
GSA 1300
GS1015
GSA1300 estate
BX16
BX17d
BX19destate
BX19d
