water pooring out underneath, help
davidp456
got water pooring out underneath my citroen synergie, any ideas please, i had a look and cant see where its coming from as views are blocked.
citroenxm
- Fallen Hero
- x 70
underneath were?? At the back? At gearbox end? At cam belt end??
Pin point the area, may give us a better idea..
Could be core plug, could be water pump, could be a broken plastic junction pipe, could be split hose...
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 94
citroenxm
- Fallen Hero
- x 70
citrov6
davidp456
citroenxm
- Fallen Hero
- x 70
From the belts!!
Water Pump, which is Cam belt driven! So thats new Cam belt and waterpump...
Water pumps are only about £25 uk prices... Cam belts? About 20 quid..
Dooing it? your self or garage...? You know which is cheapest
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
davidp456
i have done no car work at all, is it possible to do it, are any special tools needed, or is there a guide on here?citroenxm wrote:From the belts!!
Paul
davidp456
not from the belts but from something that is around that areacitroenxm wrote:From the belts!!
Paul
citroenxm
- Fallen Hero
- x 70
Ok, for you to look at. You have the radiator, in which the bottom hose goes round passed the Crank Pully, to the REAR of the engine, its just here there s 4 way water outlet, made of plastic! Ive known these to split and collapse, then theres one hose going up to the Car heater, another goes across the back of the engine to the rear of the thermostat house, and the 4th is most of the time blocked off...
So unless a pipe has split, a feel and squeeze with your have might tell you, it can only be comming from the water pump..
Im sure there is a guide on here somewere to dooing them, they are not hard, theres none of this "Verneeir" Cams, or Plastic pullys, and "Set the belt tension just ... this much ", its a very good old school basic engine!! I bit of know how would help though..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
davidp456
thanks i cant feel any water from top of engine reaching all over inside.citroenxm wrote:Ok, for you to look at. You have the radiator, in which the bottom hose goes round passed the Crank Pully, to the REAR of the engine, its just here there s 4 way water outlet, made of plastic! Ive known these to split and collapse, then theres one hose going up to the Car heater, another goes across the back of the engine to the rear of the thermostat house, and the 4th is most of the time blocked off...
Paul
jgra1
- (Donor 2021)
- x 36
davidp456
just had a quick look underneath, just cant see anything, whatever it is, is dropping onto the engine, sorry not very good with names, i think its where a gasket goes. is it called the sump?jgra1 wrote:hi Dave water pump is way down at the bottom back right of the engine..
get car on ramps and use a decent torch/light and you may be able to see more..
could be a persihed hose which is a lot better than a water pump/ cambelt job...
worth a look.
John
- x 5634
davidp456
