petrol smell inside renault espace with aircon and engine on
leeyhdr
Unread post by leeyhdr »
Hi there. Can anyone help me or give some suggestions to the problem of petrol smell inside my renault espace 1998 model with windows closed and air con with engine on. When the engine is off with air con on, there is no smell.
Have it checked with 2 different renault service station but the problem is still there.
Could not check any leaks from the fuel pump or tank or petrol hose. The air con air intake valve in front and that near the breather valve at the back (the place where prtrol is pump in ) has been sealed.
Any suggestions is highly appreciated. Thank you in advance.
lee
citrov6
Unread post by citrov6 »
i had a drip leak on my xantia at the fuel return toward the back, even though it was on the outside, the car would suck in the vapor through the blower at the front of the car. vapour spreads very fast so the leak could be anywhere outside too
Love my black v6 xant - only one with cream coloured leather too!
x 5651
Could be a leak on the charcoal cannister or associated pipework.
