Xantia keypad red and green and locked
ekaftan
x 8
Unread post by ekaftan »
Hi. A friends 94 Xantia won't start. Keypad seems to accept the code but gives steady green and red and can does not start.
Any known way to unlock it?
THanks.
Pleiades
Unread post by Pleiades »
As far as I remember..........
You need to leave it with the ignition switched on for a while (till the red / green goes to just red)
This can take up to a couple of hours depending upon how may error attempts were made.
Regards
Martin.
x 94
Unread post by citronut »
first thing to try is disconect the battery for about half an hour
if this dose not work then it might be the following
that will/could be the imobaliser, sounds like it might of died,
mine when intermitent and kept cutting the engine out, great just what you need on a motorway,
i ended up removeing the electronics which are embeded inside some very OTT armour on the rear end of the fuel pump,
lots of fun was had by all TEA HE and lots of PERCY WHAT SIT
once you have removed this you can very easily attatch a switched feed to the solanoid fuel shut off valve
regards malcolm
x 1053
Unread post by wheeler »
Which engine is it ? If both lights are on it means the keypad is not comunicating with the ECU/pump module. This could be caused by no power or earth at the engine ECU, not neccicarily a fault directly with the keypad.
Have all the fuses been checked ?
If it has one fitted check that the inertia switch has not tripped by pushing it down to re set it.
Remove the body & gearbox earth leads & clean the fixing points & re fit (even if they look ok).
Check the 30 pin multiplugs on the inner wings, they are prone to getting corroded & dirty which can cause this problem.
dieseldoggy
Unread post by dieseldoggy »
check the fuse for it under dash as i had sim prob while ago when we was checking other fault with ign on and it popped fuse 5amp one 2nd /3rd one down? on the right hand bank!
xantia 19td estate 96-7
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
If you have entered the incorrect code 3 times and locked the keypad then its a simple 30 min wait to unlock it - ignition off...
This is a fresh excersie, as a customer locked theres last sunday night, and I advised waiting 30mins, which then unlocked for them to enter the correct code and drive on...
Paul
A very sad...
1994 XM 2.1 d auto
