Saxo / Citroen alarm problem
burratha
Unread post by burratha »
Hi - this is my first post - I was referred to this forum by some kind person from Scoobynet :)
Anyway - I have a problem with the alarm on my wife's Saxo VTR. Its a citroen alarm, and has developed a nasty habit of activating quite randomly.
Is there any key or list to show if the LED flashes relate to any kind of alarm activation?
Thanks in advance.
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
You'll probably find that it's all down to one of the door locks. It was the tailgate in my case, on my Xantia. The alarm gets to thinking the door is open when it isn't. A replacement lock did the trick.
burratha
Ok. Thanks for taking the time to reply. I'll look into it :)
x 1044
Unread post by wheeler »
is it a factory fitted alarm or a dealer fit Texalarm ? doubt it will be a door lock or tailgate lock,its a different set up on saxos,it senses the doors open via seperate pin switches. see my previous post
http://www.andyspares.com/discussionfor ... IC_ID=2691
