renault scenic 1.9 dci blower speed and air con works now
gazzas c5
Unread post by gazzas c5 »
hi folks my scenic blower speed was inoperative with setting 1 and 2 only 3 and 4 worked,new resistor was needed for the blower speeds,air con now works as the fan should be kicking in when air con is switched on,fan was jammed and now freed and hey presto ice cold air con now mega great !!!! 8)
CITROEN C5 2.0 HDI VTR 04 REG
CITROEN C5 2.0 16V EXCLUSIVE 53 REG
CITROEN C5 2.0 HDI EXCLUSIVE 52 REG
CITROEN C5 2.2 HDI EXCLUSIVE AUTOMATIC 54 REG FACELIFT MODEL
CITROEN C5 1.6 HDI VTR 05 REG FACELIFT MODEL
uncle buck
x 10
Unread post by uncle buck »
A good result....doubt you will need the air con anymore this summer tho :(
Cheers.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
x 5681
uncle buck wrote:A good result....doubt you will need the air con anymore this summer tho :(
Cheers.
I needed mine this evening, red hot here. (not far from gazzaC5)
uncle buck
x 10
myglaren wrote: I needed mine this evening, red hot here. (not far from gazzaC5)
Don't your windows open :D
I'm Gosforth area.
Cheers.
x 5681
I'm Gosforth area.
Cheers.
They do indeed but the aircon is far more effective :) It was 28°C when I left work!
