XUD breather hose
crossy2425
XUD breather hose
Unread post by crossy2425 »
Does anyone have a spare or know the part number/price?
Its the 'S' shaped one that starts at the lower rear of the oil filler and goes upto the cam cover.
Mines disintegrated !
red_dwarfers
x 58
Unread post by red_dwarfers »
IIRC its about 5 or 6 quid from the main dealer...can't remember the technical name though :oops:
Oil breather hose?
Kev
'19 C4 Cactus 130 Flair
crossy2425
thanks...I believe its called an 'oil vapour hose'. Possible part number is 1180 86.
I'll give a dealer a bell tommorrow.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
I JUST bought one last week from my dealer, havent got the details in front of me now, but it was only about 5 quid... Was soo tempted to buy all 3 he had in too!!!
Paul
A very sad...
1994 XM 2.1 d auto
dieseldoggy
Unread post by dieseldoggy »
Hi same as pug one.bit of a faff to do get new jubilee clip for bottom end atleast plus if you have or buy/aquire one of those long flexible screwdriver like things with a socket end.or if not a good 1/4 drive socket set with wobbly drive.and a long handled screwdriver wide as poss.i used a franklin headgasket scraper to prize pipe off filler housing twist it so it pushes off pipe.not a great deal of room down there.
If you can't get those funny clips they use off?i got a pair of long nose oliers that are twin hinged from Halfrauds pro range.and a very worth while investment.not cheap but very good for doing all those jobs on them.ie heater plug nuts and those sprung clips on water pipes etc
Plus while you're at it i would check the other pipes etc as they could be getting very brittle
xantia 19td estate 96-7
