XM
1300L9 x1 (was 96031483) radiator XM1 2.0 carb+inj+monopoint no A/C (manual?) not turbo; XM2 XU10J2 & XU10J4R no A/C, with manual gearbox.
96086715 x1 XM1 radiator ZPJ/JPJ4 (V6 & V6 24V) with A/C, manual gearbox(?) and query possible auto up to RP 6202
96068988 x1 coolant hose (??)
96094407 x1 electro valve
96045347 x1 hydraulic pipe to reservoir hose, XM1 except 24V >RP 5928, LHD & Hydractive (PAS or DIRAVI)
96061212XX x8 XM1 & 2 hinge shaft, boot separation glass, hatch
96061992 x1 clip (??)
96068193 x1 hydraulic pipe (??)
96069570 x1 PAS hydraulic pipe, from flow divider, XM1 TD or petrol turbo, LHD or RHD, PAS
96098618 x1 rear hydraulic pipe bracket, XM1
96124324 x1 F>R suspension pipe, XM1 estate >RP 5928 Hydractive suspension
96165760 x1 hydraulic pump belt, XM1 & 2 V6 (except ES9J4) RP 5566> except improved pump
96175326 x1 front fuel supply hose, XM1 & 2 2.0 injection not turbo not 16V
96995770 x1 rear suspension unit return pipe, XM1 & 2 (most models)
CIT8518 x2 wing badge, 2.0i turbo
169915 x1 ball joint kit (??)
26208159 x9 protective tube for hydraulic hose 8.5x12.5-15
26208169 x3 protective tube for hydraulic hose 17x21-45
26235189 x1 return fuel pipe 6x8 length 2850, XM2 most petrol injection
401893 x1 adjustment kit (??)
5412798 x1 spring (??)
9170E9 x1 lock barrel (blank), alarm siren, XM1 & 2 (& Xantia)
9456501049 x1 electrical repair connector, 3 pin
95608905 x1 filter union (??)
95637978XX x1 headlight switch, XM1 >RP 5655
95639650 x1 rear suspension pipe, XM1 early DIRAVI
95639660 x1 hydraulic pipe (??)
95639705 x1 RHF brake pipe, XM1 >RP 5691 except Hydractive suspension (ABS & non-ABS, LHD & RHD)
95639976ZL x1 front foglamp switch, XM1
95639977ZL x1 rear foglamp switch, XM1
95639978ZL x1 hazard flasher switch, XM1
96015683ZL x1 HRW switch, XM1 RP 4983>
625355 x1 indicator/light stalk, XM1 RP 5656> & XM2
95640536 x1 front height corrector control rod, XM1
95640884ZQ x1 LHR wing moulding, XM1 early & estate (grey?)
95645972 x1 wheel centre cap for early alloy wheel, XM1
95656499 x1 tailgate contact switch, XM1 estate
95663018 x1 fixing set (??)
9600700XX x1 steering wheel centre pad, black, XM1 >RP 5284, speed control or radio equipment
96020082 x1 hydraulic safety valve, XM1 PAS >RP 5928
527415 x1 hydraulic pressure regulator, XM1 with DIRAVI, manual & auto gearbox, various XM2 DIRAVI & non-DIRAVI
527416 x1 (was 95588686) pressure regulator XM2 2.0i 16V saloon manual to RP 7272
527418 x1pressure regulator XM2 2.0i 16V saloon manual from RP 7273 & V6 ES9J4
529111 x1 (was 96108317) front height corrector XM 1 & 2, except 6+2 pump & anti-sink
96131150ZL x1 LH electric door mirror, XM 1
5802E4 x2 (one was 96035033) starter motor XM 2.0 carb & injection
5802E7 x1 starter motor XM XU10J4R (2.0i 16V)(+XM II?)
425296 x1 front brake pad set, XM1 >RP 5228
95667788 x28 rear brake pad set, XM1 saloon, XM2 saloon except V6 ES9J4, except DK5ATE RP 7476>
425183 x1 rear brake pad set, XM2 saloon, ES9J4, DK5ATE RP 7476>
95661814 x1 rear disc set, XM1 saloon, XM2 saloon except V6 ES9J4, except DK5ATE RP 7476>
95661796 x1 rear disc set, XM1 estate, XM2 estate
96180333ZL x1 rigidity switch, XM1 & XM2 Hydractive suspension
96051826 x4 front suspension sphere, XM1 2.0 petrol (non-turbo) & 2.1D (non-turbo), Hydractive, >RP 5938
96065505 x2 front sphere, XM1 saloon 2.0 petrol turbo, 2.1TD, V6, >RP 5938, XM1 estate except V6, estate V6 >RP 6019, Hydractive
527131 x2 front sphere, XM1 saloon & estate V6 Hydractive RP 6020> (see note: also fits others, but replace as pair)
96051827 x2 rear sphere, XM1 saloon Hydractive >RP 5942
527158 x2 rear sphere, XM1 estate Hydractive RP 6051> & XM2 estate Hydractive
75520295 x1 front rigidity sphere, XM1 Hydractive >RP 5929 (V6 >RP 6019)
95669124 x1 front rigidity sphere, XM1 Hydractive V6 RP 6020>, XM2 Hydractive various models
96045530 x2 rear rigidity sphere, XM1 & XM2 saloon Hydractive
96151895 x2 hydraulic safety valve, XM1 PAS RP 5929> & XM2 PAS
96026835 x1 LHM pressure switch (in safety valve), XM1 (DIRAVI?) & XM2 DIRAVI
96119998 x2 defect sensor (similar to LHM pressure switch above?), XM1 PAS RP 5929>, XM2 PAS
508749 x1 front anti-roll bar link, XM1 & XM2
352343 x2 front wishbone front bush (2 per arm), XM1 & XM2
352344 x1 front wishbone rear bush (1 per arm), XM1 >RP 5928
352357 x1 front wishbone rear bush (1 per arm), XM1 RP 5929>, XM2
335015 x2 front hub bearing kit, XM1, XM2 >RP 7477
374830 x1 rear hub bearing (not hub assembly), XM1 & XM2
4162H2 x1 (was 96129630ZL) ignition & door lock set, XM1 saloon >RP 6078 (no remote blades) (also estate, but no tailgate lock)
2150J5 x1 clutch cable, XM1 ME5T except D11ATE & XM2 2.0i Turbo ME5T gearbox & RHD
2150J6 x1 clutch cable, XM1 & XM2 XU10J2 (2.0i 8V) BE3 gearbox & RHD
96021645 x1 front exhaust pipe, XM1 2.0 carb & 8V injection (non-turbo) & XM2 XU10J2, non-catalyst
96021679 x1 rear silencer, XM1 2.0 carburettor, monopoint injection & XU10J2 saloon, XM2 saloon XU10J2 (2.0i 8V)
96045756 x1 rear silencer, XM1 2.0 carburettor, monopoint injection & XU10J2 estate, XM2 estate XU10J2 (2.0i 8V)
95666770 x1 front exhaust pipe, XM1 2.1TD non-catalyst, XM2 XUD11ATE & XUD11BTE non-catalyst >RP 7238
95662984 x1 windscreen, tinted, XM1 & XM2 estate
95650973 x1 L/H front foglamp/indicator lamp assembly, XM1
95650970 x1 R/H front indicator lamp unit without foglamp (in bumper), XM1
96168249 x1 L/H front sidelamp unit, XM1 RP 5876>, XM2
6205H9 x1 R/H headlamp unit, XM1 & XM2 RHD
95650962 x1 L/H headlamp lens, XM1 & XM2 RHD
95650963 x1 R/H headlamp lens, XM1 & XM2 RHD
95652973 x1 L/H rear lamp unit, wing, XM1 & XM2 saloon
95652974 x1 R/H rear lamp unit, wing, XM1 & XM2 saloon
95652976 x1 L/H rear lamp unit, lower tailgate, XM1 & XM2 saloon
95652977 x1 R/H rear lamp unit, lower tailgate, XM1 & XM2 saloon
95661888 x1 R/H rear lamp unit, wing, XM1 & XM2 estate
95661889 x1 L/H rear lamp unit, tailgate, XM1 & XM2 estate
95661890 x1 R/H rear lamp unit, tailgate, XM1 & XM2 estate
192996 x1 injection ECU, XM1 2.0i RP 4953> (??), XM2 XU10J2 & manual gearbox
96007836 x1 fuel filler flap, XM1 & XM2 saloon
96021741 x1 tailgate lock barrel support & mechanism, XM1 & XM2 saloon
95666904 x1 hydraulic pipe set (pair), PAS ram to pinion valve, XM1 & XM2 RHD & PAS except DK5ATE unvariable steering
95656456 x1 front bumper chrome moulding, XM1
96026875 x1 L/H handbrake cable XM1 & XM2 except 24V ZPJ4
96026873 x1 R/H handbrake cable XM1 & XM2 except 24V ZPJ4 LHD & DIRAVI
454563 x1 front ABS sensor, XM2, Bendix, ZPJ4 & ABS RP 7109>
643459 x1 headlamp washer pump, XM2
644889 x1 heater matrix, XM1 & XM2
6445CT x1 air temperature sampling motor (heater), XM1 & XM2
2050T0 x1 clutch kit, XM2 XU10J4R (2.0i 16V) & BE3 gearbox
96068176 x1 brake pipe from doseur, XM1 & 2, various
96068193 x1 hydraulic pipe, XM (??)
95639706 x1 L/H front brake pipe, various XM, non-ABS
95639705 x1 R/H front brake pipe, various XM >RP 5691, non-ABS
96037346 x1 front flexy brake hose, various XM 1 & 2
96995768 x1 hydraulic return pipe, L/H rear suspension cylinder, various XM
527046 x1 reservoir return hose, various XM RHD
527067 x1 suspension pipe, rear height corrector to rear hydractive sphere, various XM1 & XM2 RP 5929>
597045 x1 ignition coil, XM1 2.0i auto (??)
597060 x1 ignition coil, XM1 & XM2 2.0i manual, 2.0i turbo (??)
81668 x1 cambelt, XM2 DK5ATE (2.5TD)
901099 x1 L/H front door skin
95667858 x1 R/H rear door moulding, XM1 & XM2, painted type
95291417 x2 door glass guide, XM1 & XM2
634087 x1 number plate lamp (estate?)
710475 x1 front panel, single aperture, XM1 & XM2
6992N9 x2 engine undertray fixing plate, threaded, XM1 & XM2 diesel
701362 x2 engine undertray hinges, XM1 & XM2 diesel
96165760 x1 HP pump belt, XM1 2975cc RP 5566>, XM2 ZPJ & ZPJ4 except 6+2 pump
520007 x2 HP pump belt, 2.0 petrol except 6+2 pump
5750G5 x1 HP pump belt, XM1 2.1D & 2.1TD RP 4992>, XM2 2.1D & 2.1TD except 6+2 pump
328780 x1 driveshaft gaiter (check application)
329359 x1 driveshaft gaiter (check application)
328772 x1 driveshaft gaiter (check application)
329396 x2 driveshaft gaiter (check application)
329302 x1 driveshaft gaiter (check application)
329303 x1 driveshaft gaiter (check application)
195746 x1 pad capacity, XM1 & XM2 2.0i turbo (fits in vacuum air piping system for engine)
BX
Suspension & steering
Part number Qty Description Application RP No> >RP No RRP
96070144 1 LHF wishbone 208.63 39.67
96070145 1 RHF wishbone 208.63 38.35
95611436 1 Wishbone spindle 23.87 9.61
95637690 4 Front wishbone front bush 12.15ea 23.61
96070064 4 Front wishbone rear bush 16.36ea 30.64
95615973 1 LHF hub carrier/swivel ABS 357.08 155.68
370142 1 Rear hub & bearing Non-ABS 108.48 57.60
95035532 1 Rear hub & bearing ABS 116.24 46.40
95571695 1 LHR suspension arm Non-ABS 283.29 128.59
95637694 1 Front anti-roll bar 1.6 petrol, 1.7D, 1.9D 55.33 35.99
95597955 3 Front anti-roll bar link 3857 66.36ea 83.25
95630094 1 Steering flexible coupling PAS 21.99 13.98
95631286 1 Steering flexible coupling Non-PAS 17.74 8.65
95495440 1 Inner steering ball joint 50.35 21.00
405825 3 Inner steering joint lock washer 1.38ea 2.07
95604346 1 Steering rack gaiter LH? 22.57 13.50
95496072 1 Steering rack gaiter RH? 10.73 6.66
406621 1 Steering rack protector RH? 4.96 2.54
95496583 1 Road wheel 5x14, non-vented 61.68 28.09
540163 1 Road wheel 5x14, vented 32.41 22.68
96155310 1 Road wheel 5.5x14, vented (fits Xantia also) 38.65 17.60
Hydraulics
527207 1 Cylinder stop plate 7.25 3.70
527209 4 Pushrod retaining clip 1.13ea 3.18
527210 4 Stop plate retaining clip 1.89ea 3.86
95568737 1 Rear suspension pushrod 42.51 17.55
529122 1 Front height corrector 104.54 46.83
4048G2 1 Steering pinion valve PAS 338.37 184.94
96151895 1 Security valve 73.50 28.36
402401 1 Flow divider PAS 632.55 111.33
95588686 1 Pressure regulator 1.6 petrol, diesel non PAS 154.54 91.09
5491085 1 LHM reservoir 99.84 42.01
527108 1 LHM reservoir level sensor 9.31 6.98
95488446 1 LHM reservoir cap 5.53 2.67
5508681 1 LHM reservoir filter 18.45 11.07
527106 2 LHM reservoir filter 7.39ea 9.50
5461317 1 LHM reservoir retainer 13.08 1.19
95564253 2 Front sphere 1.4 petrol 55.42ea 70.48
95630610 2 Front sphere 1.7TD saloon, 4x4; GTi >3877 55.42ea 52.18
96024568 4 Front sphere 1.7TD estate; GTi RP 3878> 52.50ea 140.96
96087641 4 Front sphere 16V, ABS 52.49ea 140.96
96024566 2 Rear sphere Estate RP 3878>, except 1.7TD 52.49ea 54.74
96087642 2 Rear sphere 16V, ABS 52.49ea 70.48
95622818 8 Front strut return pipe 9.03ea 36.94
96127591 9 Strut return pipe clip 3.84ea 16.27
5437354 1 Accumulator sphere 81.41 48.85
95589236 1 Hydraulic pump Petrol except 16V 2411.32 211.58
520006 3 Hydraulic pump belt Early 1.4 petrol 9.33ea 11.34
91536298 3 Hydraulic pump belt Diesel except 6+2; 16V >4223 9.36ea 11.33
96030258 1 Return “octopus” 39.16 24.73
95567454 1 Main reservoir return hose Early 1.4 petrol 57.56 26.71
95603420 1 Main reservoir return hose Diesel & PAS 5167 62.99 32.91
96119048 1 Main reservoir return hose PAS 5168 45.64 25.42
95624231 1 Supply hose, reservoir to pump Petrol & PAS, except 16V 40.53 13.09
96093539 2 Pipe to brake valve RHD 3.88ea 5.45
96093540 2 Pipe to brake valve RHD 4.00ea 4.92
96093541 2 Pipe to brake valve RHD 3.79ea 4.63
96093542 2 Pipe to brake valve RHD 4.35ea 5.38
95596539 2 LHF brake pipe Non-ABS 10.32ea 10.00
95596540 2 RHF brake pipe Non-ABS 10.64ea 10.75
96093534 3 Front to rear brake pipe Non-ABS 20.51ea 27.38
96119932 3 Front to rear suspension pipe 20.61ea 26.24
96093536 1 Brake pipe to security valve 4.51 2.89
96093538 1 Pipe to front brake “T” connector 4.07 2.45
96033164 1 Pipe, flow divider to strg pinion Including 1.7TD 4102 12.18 6.38
40207A 1 Pipe set, pinion valve to PAS ram PAS, except 4x4 16.01 5.05
95592923 1 Pipe, regulator to pump Early 1.4 petrol 23.19 9.85
96028927 1 Pipe, regulator to pump Late 1.4 petrol 7.92 1.93
96020901 1 Pipe, regulator to pump 1.6 petrol, non-PAS 22.90 9.90
95576508 1 Pipe, regulator to security valve Early 1.4 petrol 22.97 4.55
95605517 1 Pipe, regulator to security valve Except 1.4 petrol 4101 20.43 8.94
95597151 1 Pipe, regulator to security valve Auto, non-PAS 4101 8.94 5.48
95567431 2 Pipe, security valve to front h/c 9.45ea 8.43
95595683 2 Pipe, security valve to rear h/c 18.08ea 15.87
95595685 2 Pipe, rear h/c to 3-way union 7.84ea 7.11
95595682 2 LHR suspension pipe 8.27ea 7.81
96117586 3 RHF suspension pipe 8.90ea 11.27
95603737 1 LHF suspension pipe 16.99 7.77
95567435 1 Pipe, “T” to LHF suspension pipe 9.04 4.17
95596564 1 Pipe, pump to flow divider Diesel & PAS 22.00 11.29
95603177 2 Pipe, pump to flow divider 1.6 petrol >RP 4101, 1.9 petrol except 16V 22.34ea 19.78
96016907 1 Pipe, pump to flow divider 16V & PAS 4223 19.54 6.08
96034027 1 Pipe, pump to flow divider 16V & PAS 4224 10.47 3.60
95596576 1 Pipe, regulator to flow divider PAS, except 16V 20.23 10.99
95596578 1 Pipe, regulator to security valve PAS 4101 13.18 5.70
95597151 1 Pipe, regulator to security valve Auto 4101 8.94 5.48
Brakes
4745L2 2 Handbrake cable 27.10ea 34.72
96011524 0 LH handbrake cable guide 4.85 SOLD
96118522 0 RH handbrake cable guide Except 4x4 10.64 SOLD
96035565 1 RHF brake disc deflector 7.03 3.20
95651079 1 Rear brake caliper 393.77 46.71
91537913 1 Rear ABS sensor Except 4x4 175.94 55.49
95661746 1 Front brake disc kit Non-vented 80.62 29.10
95624484 2 Front brake pad set 45.79ea 36.59
95661849 1 Rear brake disc kit 69.97 31.75
95650890 2 Rear brake pad set 40.20ea 30.09
95632790 0 Front flexible brake hose ABS 20.77ea SOLD
Gearbox, clutch & transmission
95591608 38 Clutch/brake pedal return spring RHD 1.35ea 11.78
95612702 2 Clutch cable Early 1.4 petrol 23.55ea 34.14
96081712 1 Clutch cable 1.6 & 1.9 petrol, 1.7 & 1.9D 34.19 20.56
96081710 2 Clutch cable 16V & 1.7TD 28.29ea 29.82
2050W2 2 Clutch kit 1.6 & 1.9 petrol, except 16V &4x4 4529 225.40ea 125.54
96134964 1 Clutch relay lever Except 16V & TD 4529? 17.23 9.22
95567189 9 Clutch relay lever pushrod Except 16V & TD 4529? 1.14ea 5.13
211810 3 Clutch relay lever adjuster screw Except 16V & TD 4529? 4.66ea 1.17
2004A1 1 Clutch cover 16V, 1.7TD, 4x4 petrol 87.56 15.26
2050W6 1 Clutch kit Diesel except 1.7TD 231.47 60.00
205208 1 Clutch kit 1.7TD 261.92 76.44
95596491 ??? Long gear rod, from lever (upper) Early 1.4 petrol
95495342 1 Short gear rod (transverse) Early 1.4 petrol 14.22 4.47
95569317 2 Relay lever Early 1.4 petrol 42.45ea 0.00
95495340 1 Long gear rod, from lever (lower) Early 1.4 petrol 35.18 16.22
96006362 1 Short gear rod (transverse) Late 1.4 petrol 7.87 3.37
95636577 1 Long gear rod (transverse) Late 1.4 petrol 17.19 6.75
95635511 1 Long gear rod, from lever (upper) 1.6 & 1.9 petrol, 1.7 & 1.9D, TD 4529 62.66 17.57
95495557 1 Short gear rod (transverse) 1.6 & 1.9 petrol, 1.7 & 1.9D, TD 4529 13.75 4.82
96049753 2 Long gear rod (transverse) 1.6 & 1.9 petrol, 1.7 & 1.9D, TD 4530 12.77ea 10.74
2454A4 1 Auto gear cable ball end 5.14 2.28
210948 1 Transfer casing gasket, large Early 1.4 petrol 12.57 5.55
210946 1 Transfer casing gasket, small Early 1.4 petrol 4.92 2.23
210912 1 Input shaft guide bush & seal Early 1.4 petrol 17.28 5.88
230214 1 Splined drive tube Early 1.4 petrol 15.91 6.93
211736 1 Clutch fork Early 1.4 petrol 14.15 9.60
212037 5 Clutch fork pushrod Early 1.4 petrol .79ea 1.45
329351 2 Outer driveshaft gaiter Various 18.55ea 11.38
328774 1 Inner driveshaft gaiter Various 23.39 8.47
329383 4 Outer driveshaft gaiter Various 20.41 34.20
329391 0 Outer driveshaft gaiter Various (ABS, GTi, etc) 32.71ea SOLD
329396 2 Outer driveshaft gaiter Solid plastic 23.21ea 22.00
95638113 1 Upper speedo cable Mk1 (for ED-Veglia, will also fit Jaeger) 19.68 5.49
75513020 0 Upper speedo cable Mk1 (Jaeger only;shorter cable) GT 19.34 SOLD
Engine & fuel system
95575329 1 Carburettor Early 1.4 petrol 194.48 0.00
95619435 1 Choke cable 18.39 8.49
95610428 1 Fuel tank pick-up & return unit Petrol 3738 15.00 6.89
95610427 1 Fuel tank pick-up & return unit Diesel 3738 23.85 8.97
156389 1 Fuel pulsation buffer Petrol injection 40.46 22.10
95594177 1 Metal fuel supply pipe Except petrol injection 9.47 6.57
95594178 1 Metal fuel return pipe 7.30 5.07
81640 1 Cambelt 16V 29.91 12.79
94957 3 Exhaust valve 1.6 petrol RP 4158>, 1.9 carb 24.35ea 45.36
94887 2 Inlet valve 1.6 petrol RP 4158>, 1.9 carb 14.41ea 13.46
51414 1 Crankshaft oilseal, flywheel end Early 1.4 petrol 17.92 0.00
51415 1 Crankshaft oilseal, timing end Early 1.4 petrol 6.60 4.59
118E5 2 Main bearing thrust washer 2.40 Early 1.4 petrol 4.00ea 2.48
118E9 3 Main bearing thrust washer 2.55 Early 1.4 petrol 15.80ea 30.36
118F0 2 Main bearing thrust washer 2.60 Early 1.4 petrol 15.99ea 20.48
209A6 1 Cylinder head gasket, std 1.20 Early 1.4 petrol 22.89 0.00
209A7 1 Cylinder head gasket, rep 1.40 Early 1.4 petrol 30.06 15.41
24939 1 Rocker cover gasket Early 1.4 petrol 5.96 2.93
25818 1 Oil filler cap Early 1.4 petrol, 1.6 & 1.9 petrol 9.97 10.78
95588076 1 Oil breather pipe Early 1.4 petrol 13.84 4.90
24974 1 Rocker cover gasket 16V 27.74 15.22
95639404 1 Air intake pipe, to filter casing? 1.7TD 21.20 7.43
91536683 1 Air filter casing, with element Various models, petrol & diesel 43.87 30.25
96059366 1 Air filter casing bracket Various models, petrol & diesel 13.80 6.78
96087419 1 Air hose, filter to throttle housing Petrol 1.9 injection, except 16V 4924 19.88 14.91
96015959 1 Air intake hose to filter Petrol 1.6 &1.9 injection, except 16V, 1.9D RP 3796> 34.65 0.00
570525 1 Alternator 1.6 & 1.9 petrol; 1.9D >RP 4921 148.36 75.00
91515530 1 Alternator Early 1.4 petrol 97.67 59.80
5705JN 1 Alternator Late 1.4 petrol, 5/88>9/91 91.98 65.00
5705JS 1 Alternator Late 1.4 petrol, 9/91> 122.82 110.50
5802EQ 1 Starter motor Diesel, CL5 167.40 104.00
580245 1 Starter motor Early 1.4 petrol 225.40 55.02
95495358 1 Aux belt tension roller Early 1.4 petrol 82.43 38.65
95588568 4 Front exhaust pipe Early 1.4 petrol 4195 59.19ea 95.28
96012198 2 Exhaust down pipe Late 1.4 petrol 4196 103.97ea 62.14
96076275 1 Front exhaust pipe 1.6 & 1.9 carburettor 107.82 41.22
95634351 1 Transverse silencer Flange fittings (e.g. TD, GTi) 78.19 26.33
96048419 1 Rear silencer Estate, 1.7TD & injection 77.27 35.93
30446 1 Sump gasket Early 1.4 petrol 9.90 4.51
95638829 8 Oil filter Early 1.4 petrol 11.27 20.48
113152 1 Oil level sensor 1.6 & 1.9 petrol 35.35 13.20
117824 1 Oil breather/filler neck 1.6 & 1.9 petrol, 16V 14.52 7.56
184472 1 RH engine mounting Late 1.4 petrol 26.21 6.92
1807P0 1 Lower rear engine mount, cast Late 1.4 petrol 30.09 52.44
120169 1 Water pump Early 1.4 petrol 86.94 27.13
120681 1 Water pump gasket Early 1.4 petrol .98 .36
95593786 1 Radiator fan cowling Except 16V & 1.7TD 43.61 0.00
95634724 1 Radiator fan shroud Petrol except 16V 10.72 5.64
95633842 3 Upper radiator panel Diesel 3796? 6.73ea 13.23
95601742 2 Radiator fan shroud Diesel except 1.7TD 27.45ea 26.74
95635181 1 Radiator 1.7TD 267.21 137.38
95639271 1 Lower radiator panel 1.7TD 6.31 3.95
95593786 1 Radiator fan panel Petrol & diesel, GATE 43.61 0.00
95601821 1 Radiator fan panel Petrol & diesel, AOP 52.40 22.38
95591751 4 Lower fan panel bracket 2 fan system (e.g. 1.7TD, 16V) 6.75ea 14.52
95566628 1 Top radiator hose Early 1.4 petrol 52.16 24.51
95610901 1 Metal coolant pipe, back of head 1.6 & 1.9 petrol, except 16V 18.17 8.47
96170006 1 Top radiator hose 1.9D, 6+2 pump? (remote filter) 48.81 22.37
1307J5 2 Hose, exchanger to thermostat 1.9D manual (remote fuel filter) 8.37ea 10.64
1307W2 1 Hose, to metal pipe back of head 1.9D (remote fuel filter) 40.93 24.06
95587675 1 Top radiator hose 1.7D, 1.9D (remote fuel filter) 3796 25.99 22.41
96162612 1 Metal coolant pipe, back of head 1.7D, 1.9D (remote fuel filter) 3796 10.79 5.39
95638396 0 Top radiator hose 1.7TD 23.70 SOLD
96164164 1 Bottom radiator hose 1.7TD 5638 38.89 15.86
190413 1 Fuel filter head, Roto Diesel Diesel (remote fuel filter) 73.02 50.51
95595188 1 Fuel filter unit, Purflux Diesel (remote fuel filter) 118.37 61.70
594029 2 Distributor cap & rotor, Ducellier Early 1.4 petrol, 1.6 petrol etc 24.67ea 37.68
594031 2 Distributor cap & rotor, Ducellier Early 1.4 petrol, 1.6 petrol etc 24.64ea 33.98
594047 1 Distributor cap & rotor, Bosch Late 1.4 petrol 41.48 24.76
594548 4 Ignition module Petrol, inc 16V 73.90ea 139.68
97533275 1 Ignition lead set Early 1.4 petrol 52.44 20.37
5967N9 1 Ignition lead set Late 1.4 petrol 43.86 21.53
597043 2 Ignition coil Late 1.4 petrol, etc 57.78ea 57.92
95636601 2 Ignition lead set Early 1.6 petrol 36.81ea 36.68
95659598 1 Ignition lead set Late 1.6 petrol 59.49 28.57
597042 0 Ignition coil 16V 48.06 SOLD
9401445798 1 Air filter foam Early 1.4 petrol 4.16 1.60
9401906148 10 Diesel fuel filter, Roto Diesel Remote fuel filter 8.35ea 64.79
95608910 8 Diesel fuel filter, Purflux Remote fuel filter 17.30ea 58.64
SRV503 8 Petrol fuel filter Carburettor 4.66ea 17.04
CITBP6EFS 17 NGK spark plug Early 1.4 petrol, 1.6 & 1.9 petrol > 7/87 2.87ea 13.26
CITBCP6ES 38 NGK spark plug Late 1.4 petrol, 1.6 & 1.9 petrol 8/87> except cat & GTi 2.87ea 26.22
CITBCPR6ES 11 NGK spark plug 1.6 & 1.9 petrol with cat except GTi 3.99ea 15.25
CITBCP7ES 4 NGK spark plug GTi 8V except cat 2.87ea 3.52
CITBCPR7ES 12 NGK spark plug GTi 8V & 16V with cat 3.86ea 12.00
CITBCP7ET 14 NGK spark plug 16V except cat 6.57ea 30.80
Body mechanisms
95562445 2 RH external door handle 12.86ea 7.58
95562446 1 LH external door handle 17.42 4.76
95573650 1 LHF door lock mechanism For central locking 49.92 19.95
95573657 1 LHR door lock mechanism For central locking 53.31 19.11
95573658 1 RHR door lock mechanism For central locking 37.57 19.34
95564093 1 Tailgate catch Saloon without central locking 36.48 16.43
95566740 1 Tailgate catch Saloon with central locking 59.22 30.53
95564118 1 Tailgate lock button Without central locking 11.98 8.35
95610886 1 Tailgate striker Estate 3.31 1.61
95612096 1 Bonnet safety hook 13.07 9.29
75530712 1 Bonnet lock 33.28 15.19
95635160 1 Bonnet release cable 9.77 8.30
95608415 1 Bonnet striker pin Plastic bonnet 6.86 3.49
95564275XX ??? Rear seat back release handle
95570569 1 LHR seat back lock 23.86 12.53
95570570 1 RHR seat back lock 23.86 8.18
95649395 1 LHF electric window mechanism CIM 132.49 37.91
95649397 1 LHR electric window mechanism CIM 94.37 31.83
Body electrical
95494828 1 Front wiper motor, Marchal 167.76 108.63
95623204 0 Front wiper motor, Bosch 96.57 SOLD
95623205 1 Front wiper mechanism, Bosch 108.86 33.69
95589142 3 Front wiper arm 32.46ea 31.89
95495714 1 Windscreen washer spray bar 11.66 5.31
95633058 1 Front screen washer bottle 32.79 4.65
95633057 1 Rear screen washer bottle 12.77 6.18
643466 1 Windscreen washer pump 11.63 7.06
97533660 1 Wiper stalk 48.79 17.94
95618753 1 Dashboard fuel gauge, Veglia Except GTi 47.99 0.00
644590 1 Heater fan resistor 3710 45.38 25.18
6155J9 1 Digital clock 92.67 37.50
96070197 0 Ignition/door lock set Cross cut key 97.08 SOLD
95662479 1 Ignition/door lock set Flat key 5956 62.70 43.93
96008430TR 1 Rear wash/wipe switch Saloon 4131 19.42 9.73
6239G4 1 Hazard flasher switch 32.06 13.15
97523100 1 Front foglamp switch 13.68 9.46
95634839TR 1 Heated rear screen switch 4131 28.78 13.56
95634839FXX 1 Heated rear screen switch 18.08 11.54
96085588 1 Battery positive cable 1.6 petrol & 1.9 GTi 39.54 16.85
96091774 1 Battery positive cable 19TRS; diesel RP 4983> 20.24 11.84
96030080 1 Battery positive cable Late 1.4 petrol 18.28 6.09
95584782 1 Battery negative cable 19TRS, 1.4 petrol 8.97 8.73
95569042 1 Battery negative cable 1.6 petrol, 1.9 GTi, diesel 22.29 10.53
95588298FYD 1 Hazard flasher switch, grey Mk1 24.34 14.83
95588305FYD 1 Light switch, grey Mk1 12.57 9.48
Body structure
95630375 1 RH headlamp mounting panel 17.21 6.47
95605366 1 Bonnet seal, above headlamp 4.28 .92
95612062 1 LHR wing Mk2 saloon 177.26 60.97
95612063 1 RHR wing Mk2 saloon 177.26 82.79
95568456 2 Fuel filler flap 40.11ea 39.20
95631758 1 Front subframe Early 1.4 petrol 249.64 161.68
95563211 2 LHF wing Mk1 135.10ea 95.92
95563210 2 RHF wing Mk1 141.93ea 104.50
95619149 1 Front bumper Mk1 167.28 71.24
95565244XA 1 Front bumper grille Mk1 62.95 18.29
95587856 2 Rear panel assembly Saloon 138.63ea 90.34
95633140 1 Rear subframe Except 4x4 408.87 162.35
95563310 2 Front bulkhead cowl top 52.20ea 66.90
95631043 2 Front bumper side bracket 10.79ea 10.72
95645962 1 LHF inner arch panel 167.47 121.42
95645961 1 RHF inner arch panel 104.49 98.41
95615414 4 LHF inner wing side panel 51.25ea 75.40
95615413 2 RHF inner wing side panel 43.65ea 35.00
95595027 1 LHF chassis leg 59.89 67.15
95595026 1 RHF chassis leg 111.84 67.15
95560885 1 LHF chassis leg end bracket 7.60 4.57
95560884 1 RHF chassis leg end bracket 5.50 2.58
95575083 1 Battery support bracket Except early 1.4 petrol 31.31 12.26
95587858 1 LHR lamp panel Saloon 41.20 15.15
95617022 1 RHR inner wheel arch assembly Saloon 163.66 73.70
95587860 1 LHR upper inner wheel arch Saloon 93.86 57.48
95567708 1 LHR floor leg Estate 22.58 7.87
95616854 1 Rear crossmember Estate 116.46 50.00
95616852 1 LHR towing eye Estate 31.11 16.78
95616853 1 RHR towing eye Estate 34.64 16.78
95615179 3 Lower front crossmember 4071 51.54ea 48.03
95616626 2 Locking plate, front panel 15.35ea 23.02
Body trims & mouldings
95619577 1 LHR wheelarch protector Estate 24.31 11.56
95619579 1 LHR wheelarch protector Saloon 26.23 9.82
95604802 2 Rear wing upright seam trim Saloon 2.75ea 2.66
95570784TR 1 Front seat backrest moulding 24.84 12.86
95661828 0 LHF bumper duct/cover 16V Phase 2 47.26 SOLD
95595330 1 Wheel trim Mk1 RS, etc 20.36 14.19
95632315TL 1 RHF door capping, grey 15.78 11.84
95619108 1 Rear bumper/tailgate moulding Estate 83.75 24.05
95619724 2 Tailgate moulding insert Estate 25.85ea 19.54
96059179 1 Badge, TZD TURBO Plaque style (earlier) 6.22 2.92
95582304 5 Bonnet chevron, chrome 4.58ea 15.75
95609863 0 Bonnet chevron, black 3.40ea SOLD
95568167 3 Bonnet catch protector .41ea 1.14
95589671 4 Bonnet buffer .99ea .60
95589346 3 Wing/bonnet rear edge seal block 1.97ea 2.79
95643658XX 1 Front bumper corner end set, black 6.77 SOLD
95643658YB 1 Front bumper corner end set, grey 6.53 3.24
95624914 1 LHR arch moulding 16V, late Phase 1 & Phase 2 4496 149.69 73.74
95653193 1 LHR door moulding 16V Phase 2 89.13 22.94
95653195 1 LHR wing moulding 16V Phase 2 38.47 12.38
95612059XX 1 RHF wing moulding, 27mm 4754 7.92 3.51
95633444 1 RHF wing moulding, 27mm Stainless insert 4754 4.37 1.38
95633445 1 LHF wing moulding, 27mm Stainless insert 4754 4.91 1.27
95633443 2 LHR wing moulding, 27mm Stainless insert, saloon 4754 16.14ea 9.72
95612064XX 1 LHR wing moulding, 27mm Saloon 4754 9.73 3.44
95632337XX 1 RHR wing moulding, 27mm Estate 4754 17.07 9.92
95612072XX 3 RHR door moulding, 27mm 4754 16.40ea 24.36
95633439 1 LHF door moulding, 27mm Stainless insert 4754 23.39 8.80
95633438 1 RHF door moulding, 27mm Stainless insert 4754 22.16 10.32
95612058YB 1 LHF wing moulding, 27mm 4755 7.92 3.51
95612064YB 1 LHR wing moulding, 27mm Saloon 4755 9.17 3.97
95612065YB 1 RHR wing moulding, 27mm Saloon 4755 9.17 4.59
95632337YB 1 RHR wing moulding, 27mm Estate 4755 12.45 8.17
95612069YB 1 LHF door moulding, 27mm 4755 15.82 5.79
95612070YB 1 RHF door moulding, 27mm 4755 15.82 6.97
95612072YB 1 RHR door moulding, 27mm 4755 15.82 7.10
96044541YB 1 LHF door moulding, 52mm 4755 38.94 20.90
95656536 0 RHF wing moulding, 52mm Painted (Athena, Hurricane) 4755 27.74 SOLD
95653193 0 LHR door moulding, 52mm Painted (Athena, Hurricane) 4755 89.13 SOLD
95585105 1 RHR wing anti-chip tape Mk1? 5.58 4.19
CIT8021 2 Pinstripe St Tropez 10.91ea SOLD
CIT8055 1 Pinstripe Rendezvous 11.42 7.52
CIT7209 3 Badge Meteor 6.81ea 13.95
CIT8511 1 Badge, 19TXD Later version 3.01 1.60
CIT8090 1 Stripe kit Hurricane TZD Turbo 24.00 14.88
95612078 1 RHF plastic arch liner 37.81 13.07
95612060XX 2 Front bumper side seal 27.06ea SOLD
95561259 1 Rear door aperture seal 79.54 17.60
95584997 3 LHF wing moulding Mk1 9.09ea
95584996 1 RHF wing moulding Mk1 9.09 3.07
95568912 1 LHF door moulding Mk1 19.79
95568911 1 RHF door moulding Mk1 19.79 6.69
95568913 2 RHR door moulding Mk1 19.79ea 13.38
Glazing
95619450 4 Windscreen seal Saloon 50.79ea 68.92
95619451 1 Windscreen Clear 136.97 63.73
95653182 1 Windscreen Green tint 4496 142.89 89.66
95560673 1 RHF door glass Clear 53.50 19.86
95560674 1 LHF door glass Clear 29.72 15.30
95560676 1 LHF door glass Bronze tint 4495 27.00 25.61
96050176 1 LHF door glass Green tint 4496 52.19 21.55
95633344 1 LHR door glass Bronze tint 4495 32.49 30.92
96050178 1 RHR door glass Green tint 4496 55.52 26.29
96050179 1 LHR door glass Green tint 4496 62.95 26.29
96050180 1 RHR door ¼ glass Green tint 4496 17.94 7.71
95496514 1 Tailgate glass Clear, heated, saloon 91.10 37.60
95606651 1 Tailgate glass Clear, heated, estate 102.62 0.00
96051539 1 Tailgate glass Green tint, heated, saloon 4496 130.65 51.34
95592669 1 Tailgate glass seal Saloon 20.92 7.55
Miscellaneous
95552823 1 Spark plug wrench 3.73 3.97
96078629 1 Wheelbrace 4588 8.31 5.78
95495316 1 Heater matrix 75.40 40.01
95595456 2 Air extractor vent filter Saloon 2.15ea 3.22
95597261 1 Air extractor vent filter Estate 1.42 .78
95632283 1 LH mirror, manual 56.44 33.16
96077969 0 RH mirror, electric & heated 101.98 SOLD
95619708 1 LH mirror glass, electric 14.41 8.62
95633648 1 Mirror control knob, manual 1.41 .73
95624967 2 RH mirror control knob, manual 5.10ea 8.08
95638372 3 Mirror handle foam seal .76ea .78
95495888 1 RH mirror, manual (with handle) Mk1 90.05 44.26
95495892 1 LH mirror, manual (with handle) Mk1 64.95 47.09
95616731 2 RH mirror glass Mk1, “HOHE” 11.39ea 13.68
95614610 1 LH mirror glass Mk1, “BRITAX” 16.14 8.35
96047324 1 Heater hose to rear housing 1.7TD 5637 25.67 10.39
96090355XX 1 Coin box 14.67 5.87
95570247 1 Boot trim, rear panel Saloon 21.80 3.11
95576719 1 Rear lamp earth harness Saloon 15.54 4.12
95569072 1 Rear lamp harness, between lamps Saloon 21.89 16.42
95637364 2 Front brake pad wear loom 28.05ea 19.88
95561136 1 Co-axial cable 18.68 9.76
6451Z7 2 Heater control knob, grey 7.33ea 7.20
7903076124 1 Heater control cable clip .47 .21
95631221TR 1 Glovebox lid release button 4131 13.16 4.42
CX
32150 x1 timing gasket
328749 x1 driveshaft gaiter
5411688 x16 pipe gasket
5413322 x2 seat tensioner
5429899 x3 driveshaft snap ring
5437271 x2 pin
5439219 x2 retaining pin
5443746 x1 oil filter
5446927 x4 retainer
5447754 x1 R/H rear door skin
5450453 x1 hydraulic pipe
5450454 x1 hydraulic pipe
5451214 x1 tube sleeve
5453876 x1 brake pad set
5466544 x3 cup
5474942 x1 support flange
5477235 x6 washer
5478288 x1 hydraulic pipe
5481728 x1 L/H frame moulding
5481734 x1 frame moulding
5485737 x2 contact set
5488090 x4 retaining clip
5507214 x1 wheel centre cap
5509113 x1 hydraulic pipe
5750F1 x2 drive belt
5750F3 x1 drive belt
75522650 x3 condenser
75532237 x1 mirror glass
75532238 x1 mirror seal
7700652109 x1 fuel pump spacer
7903067102 x1 spindle
7903097289 x2 bulb connector
7920001108 x1 tank unit cap
95494356 x1 drive socket
95496457 x1 clutch cable
95499237 x4 rubber hose
95532953 x1 driveshaft gaiter
95538130 x1 L/H door mirror glass
95539806 x2 R/H door mirror glass
95554427 x1 R/H protective strip
95558838 x5 wiring connector blade
95572533 x1 air filter
95572783 x1 R/H front light
95581153 x1 R/H adhesive strip
95585712 x2 bulb holder
95590849 x1 L/H quarter glass
95597159 x1 pin
95597300TL x1 L/H pull handle
95599227 x1 hydraulic pipe
95606079 x1 L/H lower panel
95606094 x1 L/H front wing protector
95606095 x1 door protector
95606098 x1 door protector
95607723 x1 driveshaft gaiter
95609022 x1 suspension pipe
95612292 x1 L/H frame moulding
95612294 x1 door window strip
95612296 x1 rear door embellisher
95615124 x1 fuel flap lock barrel
95619163 x1 hub bearing
95623760 x2 plastic seal
95624988 x1 contact set
95632523 x1 union
95632552 x2 rubber buffer
95632636 x1 filler plug
95634824 x1 bonnet cable
95649392 x1 R/H rear window mechanism
95661850 x1 rear brake disc set
96024193 x1 L/H rear window mechanism
96026126 x1 hydraulic pipe
Also GS/A and VISA if required
Contact
PETE SHAW
N T SHAW OF LOUTH
NORTH HOLME ROAD
LOUTH
LINCS
LN11 OHQ
TEL: 01507 603382
FAX: 01507 609198
parts@ntshawlouth.citroen.co.uk
No sensible offer refused! these are all genuine NEW old stock
HUGE CITROEN PARTS SALE
tim leech
- x 12
1994 XANTIA 1.8i SX 132k, From new,
1985 BX 19GT the beige wonder
red_dwarfers
- x 58
tim leech
- x 12
tim leech
- x 12
- x 8391
red_dwarfers
- x 58
citroenxm
- Fallen Hero
- x 70
tim leech
- x 12
