Squeaky ZX brakes
Chevron Terry
Squeaky ZX brakes
Unread post by Chevron Terry »
Hi ,
Driving to work this morning I noticed , a squeak , as I touch the brake pedal , as I press harder , the squeak disappears .
Any ideas ?
Many thanks
Terry .
hobblerian
Unread post by hobblerian »
Its just normally small vibrations in the pad, as you press harder they are unable to move so much. Clean up then re-apply coppa-slip or similar to backs of front pads, where they contact the pistons and calliper. That normally stops it, also where they bottom of the pad sits in the calliper is always worth a smear. You can then check all you pad thicknesses while you are about it.
Previous 90H S1 XM 2.1td SD Manual
Current 97P S2 XM 2.1td VSX Manual
Chevron Terry
ZX Squeaky brakes
Thanks for the reply,
The front pads are pretty new , with 10% wear .
So I will try the Coppa product .
Thanks again
Terry
x 94
Unread post by citronut »
if its the rear squeeking then its more than likely down to brake dust in the drums, that is if you have drums on the rear of your car,
remove the drums blast out with compresed air bung it back together,
or as you say its just had new front pads there might be a lip on the inside and out side edges of the discs, this can cause a squeek when it cuts into the pad material,
regards malcolm
uncle buck
x 10
Unread post by uncle buck »
Also check that the friction material is not cracking away from the metal on the pad / pads, I have seen this a few times & it can causes a squeal.
Cheers.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
