C5 fault codes
damasast
C5 fault codes
Unread post by damasast »
Serious suspension fault appeared on display car seems ok but now have noticed centre buttons do not alter suspension, Had codes read got c1102 & c1135 one surposed to be steering sensor and other a vavle on suspension some where, Can any one point me in the right direction
Dave :?
x 1056
Unread post by wheeler »
have the basics been checked like fuses (including the maxi fuses under the main underbonnet fusebox) & fluid level ?
damasast
All basics checked fuses etc loose connectors broken wires but still no joy.
cachaciero
x 9
Re: C5 fault codes
Unread post by cachaciero »
damasast wrote:Serious suspension fault appeared on display car seems ok but now have noticed centre buttons do not alter suspension, Had codes read got c1102 & c1135 one surposed to be steering sensor and other a vavle on suspension some where, Can any one point me in the right direction
Dave :?
You don't say what model it is i.e is it H3 or H3+.
If H3 the only valves are in the BHI main pump unit.
Wouldn't lose to much sleep over the steering sensor.
Cachaciero.
damasast
Its the H3 system
