My question is,if i do it myself,will the ABS light have to be reset,or will the ecu detect no fault & clear itself??
The dealer charged £40 for the fault code,around £10-£25 cheaper than the 4 French indies in Bristol!
Also,seem to have a slight diesel leak around the fuel injector on the l/h side,nearest the camshaft.Looks like the sealing ring/fire ring???
Is that a fairy easy fix?Looks like a few pipes to remove,but access is great.
Cheers,Neil.
