C5 Central Locking problem
tictac77
Unread post by tictac77 »
remote key is not working but I have been able to lock the car with the key but today that has stopped working. when i ,lock the car with the key the front doors lock but the back ones don't. The boot will not open either
Does anyone have any experience of this and how to solve as I currently cant leave the vehicle
dnsey
x 19
Unread post by dnsey »
First thing to try is disconnecting the battery and resetting the system, whch can solve all sorts of peculiar behaviour! A search here will bring up the correct procedure.
tictac77
Thanks for the advice thats done the trick :D
Only problem now is the electric windows are only going up slightly
x 5668
The auto windows need to be reset.
Hold the button in the up position and let the window close but keep the button held for a further ten seconds. This resets the anti pinch system and the windows should then open and close properly.
You will also need to reset the auto lights and washers, auto volume on the radio and the automatic locking if you have it.
x 1934
Unread post by Paul-R »
myglaren wrote:You will also need to reset the auto lights and washers, auto volume on the radio and the automatic locking if you have it.
When I did the full battery reset procedure I didn't have to reset any of those afterwards. Admittedly I haven't got auto locking set anyway but the others were still active.
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
Funny that I should read this topic this morning. Yesterday when I went to the car, the remote wouldn't open the doors. I used the key in the lock which started the alarm. That stopped when I started the engine. I disconnected the battery and that got the remote working again.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
[email protected]
Unread post by [email protected] »
hi all
Were is the battery in a picasso i just broght mine yesterday and i cant find it also i find the remote locks the doors but will not open them any ideas
cheers
Drives
51 Reg Citroen C5 SX 2.0 16v
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
[email protected]
I BELEVE its under the passenger seat! I agree its DEFENATLY NOT under the bonnet...
I followed the battery leads, and they disapeared into the bulk head..
Paul
A very sad...
1994 XM 2.1 d auto
x 1056
Unread post by wheeler »
Yep, deffo under passenger seat.
pk7478
Unread post by pk7478 »
wheeler wrote:Yep, deffo under passenger seat.
Good arrangement :D
Especially when voltage regulator on alternator damaged and "gives" voltage proportionaly to engine turns :D
[email protected]
Hi all
Thanks guys ive found it :)
The prob with the central locking is the keyfob the buttons are missing and i can operate the micro switch on the big locking button but not on the small opening button (it worked with a pen) so i need a new key fob case with buttons
pete.........................
Drives
