I am a taxi driver and i have been hearing from other drivers that there is a problem about the 60k mark for clutch/flywheel on these diesel engines.? had i known 1 day earlier i could have saved a fortune by getting the work under warranty. here is my story, if anyone can point me in the direction of additional information regarding this problem. I will try to use the sale of goods act to get recompense. I also have to apply in writing to customer care peugeot in the hope of reclaiming some of the charges.
I would like help in showing that it is a "Well Known Problem" where can i find the relevent info? I just had mine in for a service at 59,995 miles. Got a new headlight (condensation) under warranty, they also stated that the clutch was rough and may need replacing. they quoted £660+vat. I got it done across the road for £380 & got a taxi free (normally £30 per day) to carry on working. However it turned out flywheel gone too, the final bill was £1100. That night whilst working i spoke to another taxi driver who had just had his clutch/flywheel replaced under warranty, 49k He only paid 2.2 hours labour +clutch. I was being quoted 7.9 hours labour! Had i left it with peugeot, i would have got flywheel under warranty too. I now need to reclaim charges retrospectively. I would like info as to how long a flywheel should last approx! and how long these in the 307sw are lasting! Any help much appreciated. Had i been informed that in 90% of cases flywheel would need replacing when doing the clutch i would have left the job with peugeot rather than looking for the cheaper option, Also when i had put car in for the service i had enquired about extending my warranty, they seemed reluctant/unwilling tp provide any information. instead said i could get that anywhere, i should contact someone like ????. had thay offered me a product there and then i would have willingly signed it.
Flywheel problem-56 plate 307sw 1.6hdi
uncle buck
- x 10
Sorry to hear of your misfortune
I believe your car will be fitted with what is called a "Dual Mass Flywheel" (DMF)
The car still has a clutch plate but the flywheel works differently to a flywheel on a standard clutch set up.
These DMF have given problems on lots of makes of cars.
From what I have heard the flywheel is always changed when a clutch needs replacing with a DMF as it's nearly always the flywheel that causes the problem & not the clutch plate.
Search google for Peugeot Dual Mass Flywheel & you will find lots of info & stories of problems.
HTH.
Cheers.
HTH.
Cheers.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
- x 94
hi and welcome
just try asking you dealer or there parts depot manager how often and what sort of year and mileage they have been doing this joob under waranty,
i find my local pud parts people very very helpfull and honest,
maybe you could get them to put it in writting also the fact they had told you the clutch willneed replaceing, as they would have known the DMF almost certainly will need replaceing at the same time
regards malcolm
regards malcolm
spic01
Xaccers
- x 188
Not much use to you now, but for anyone in the future, I'm sure there is an aftermarket non dual mass flywheel (ie a solid one) that can be fitted instead, negating the need to replace the flywheel every 60K
DIY sphere tool
DIY sphere tool
matchplayers
Phone number for peugeot
Thanks for the help guys, searching for dual mass flywheel, gave me lots of advice that i was looking for. I am currently writing to peugeot to try and reclaim flywheel cost, retrospectively. ( i should try for some labour costs too)I can assure all who are reading this that if they wont pay i will use the small claims court to try and recover the cost under the sale of goods act. As folk are saying, "Not fit for purpose"
here is a direct number for peugeot customer care:-02476884000
Ross_K
- x 110
Here's a company in Northern Ireland who convert DMFs to solid flywheels:Xac wrote:Not much use to you now, but for anyone in the future, I'm sure there is an aftermarket non dual mass flywheel (ie a solid one) that can be fitted instead, negating the need to replace the flywheel every 60K
http://www.exact-spec.com/a-float-flywheel.html
Costs £200 upwards apparently...
Deanxm
- x 87
Hi all, DMF failure is extreemly common, ive heard of units failing at 35k miles which just isnt on, my friends transit had to have one at 55k and again at 90k the second time it went we made sure a solid one went back in, i dont even see the point of the DMF, its minimal benifits do not outweigh the poor life span or high cost of the units and in my opinion at least they should never have been used.
Good luck
D
Good luck
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
- x 8448
Wheeler made a comment in another thread that they make cambelts last longer
Quite how that works I'm not sure. So, all the money you save in not having cambelts replaced goes into having a DMF replaced at cambelt-like intervalsWheeler wrote:timing belt replacement interval of 160,000 miles (or 10 years). The extended intervals are one of the 'advantages' of having a dual mass flywheel.
- x 1060
