Engineering favour
jgra1
(Donor 2021)
x 37
Engineering favour
Unread post by jgra1 »
for some beer tokens, could anyone with a drill press drill two holes in something for me :twisted: and then tap two bronze bushings in?
The holes are 25/64" which I make 9.92 mm.. a 10mm bit would be fine in this case though.. I can use some locktite...
I will post the item and provide a prepaid jiffy for it to come back to me :)
see latter part of this page :
http://www.quadrajetcarburetors.com/bus ... tions.html
thanks
J
x 8391
Consider it done John :D
Be more than happy to. Just logistics to consider. I need a run dow to your bailiwick with Malcolm's seats. Perhaps we can tie it in somehow...
Any thoughts?
jgra1
(Donor 2021)
x 37
could do Jim
:D
I need to order the bronze from the states :( but the van is off the road till the carb is back on, and also is booked into a camp site in cornwall in about 3 weeks :twisted: :shock:
Its no prob to post the baseplate to you, it weighs nothing.. will see how long it takes to get the bits....
x 8391
OK John, no problem at all,
As soon as you have the bushings, either post it or pop up and have it done on a while you wait basis..
Looking at the webpage, i see what it is all about now 8)
jgra1
(Donor 2021)
x 37
hi Jim parts ordered :) 5-10 days .. will keep you posted..
:D
am about right through August pretty much.. dont mind popping :)
