Renault Scenic :water dripping through roof light!
jackster
Unread post by jackster »
I have a 2000 renault scenic , every now & then or when it's been raining heavily , water drips through the central locking indicator in the roof panel, does anyone have any idea what is causing it? Is it a common problem?
Hope someone can help ,
Johnny :?
x 5633
Where is the radio antenna?
The gasket on these leak after a while.
Loosen the roof lining, remove the antenna base, clean the surfaces and either fit a new gasket or smear a trace of silicon sealant on the mating surfaces.
