Having to hold Laguna 2 start button.
cookie boy
Unread post by cookie boy »
Hi, i have a 02 laguna dci est, and for some reason the start button will not function with a single press any longer? I now have to hold in the button untill the engine fires up, not the end of the world i know, but bloody anoying lol!
Thanks in advance for any help. Steve
cookie boy
I have done a dignostic check & its coming up with clutch switch which sounds a very possible cause to me. I assume its a sort of safety mode as it doesnt know weather the clutch is pressed or not on startup?
I have the switch on order & will update.
martink
Unread post by martink »
Hi,this fault is normally the card reader, I've done a few of these but hope the clutch switch fixes it for you.
cookie boy
Hi, I have fitted the switch to no avail!..I guess your probably right with the reader, could it be fixed/cleaned or anything?
Cheers Steve
uncle buck
x 10
Unread post by uncle buck »
There are detailed instruction on how to remove & fix the card reader in thread #19 at the link below....
http://www.renaultforums.co.uk/showthread.php?t=2313
Good luck.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
cookie boy
Thanks for finding that link uncle buck, I feel sure I can do the job entailed & hope to have it fixed soon :D
Thanks again Steve
uncle buck
x 10
No problem, hope it sorts your problem.
Let us know how you get on.
Cheers.
telderv
Unread post by telderv »
have had the same problem, it was the battery not given enough oomph, a quick charge sorted it
LAGUNA II 1.9DCI DYNAMIQUE
