I have a 97 Xantia TD, served me well with almost 225K on the clock. Changed the gearbox @216K because of a whine and now the one I put in is starting the same moaning !- It seems to related to the left hand drive but its not a wheel bearing - jack up one wheel at a time - noise there when left hand spinning on its own. Anyway - have been keeping the eyes open and have found an 01 Xantia HDI SX < 100K (supposedly) on the clock and am tempted to have a look at it. Asking price seems a bit high but I'm sure its negotiable (am in Ireland). I know the hdi wouldn't be as diy friendly enginewise with the extra electronics, but having had Xantia TDs for the last 9 years am pretty much in tune with the rest of the car mechanically !. Any thoughts ?
Brian
Hear it out or change dilema !
citroenxm
- Fallen Hero
- x 70
Firstly, an 01 HDi SX is fairly rare, most 2000 and 01 Xantias are either HDi 90's or Petrols (No doubt some one will shout at me for saying that, but its what Ive found looking around)
100k is ok if theres a good history, and the high pressure pump in the tank has been changed... whats the good price? Your in Euros, unless your in Northern Ireland (I Think)
the HDi lumps are hard to asses.. some, on here too, have got good mileages from them, others have not done so well... its down to treatment I guess, and quality of fuel used..
Me? Id actually consider going for it, the driving pleasure from the HDi is AMAZING especially in 110bhp form, and is pretty good on fuel too! 48mpg to about 50mpg..
And its one of the LAST Xantias too and in a bloody good spec.. SX is well kitted out, if almost everything you will need!
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
BrianM
Ross_K
- x 110
BrianM
Ross_K
- x 110
falling-out-with-my-car
- x 25
my RHD Xantia always wines in 3rd gear it had third replaced before I bought it, I give it some wyns transmission lubricant at oil changes and it quite'ns downs quite a lot.
I drain the box over night measure out the oil minus the wyns add the wynns stir it in and refill via the breather beneath the air filter with a plastic bottle with bottom cut out and a clear plastic hose on the end the filling process is slow but it coats the gears as it fills.
stops the clunky gear change when the engine is cold to.
regards Nigel.
regards Nigel.
