RENAULT MEGANE INTERMITTANT STIFF GEARBOX ANY IDEAS HELP!!!
Danny140986
Unread post by Danny140986 »
ok i got my megane not so long ago, however i'm having a problem where the gearbox keeps going stiff. this only happens as the car is being driven, when its been stood it feels totally normal then slowly the more it's used it feels like it's stiffening up.
when i say stiff i don't mean actually going in and out of gears, but more the movemnt in neutral, when the car is stood and 1st used the gear stick springs back to the middle as normal but the more it's used it stops doing that and will just stay whereever you put it up down side to side.
Any ideas would be greatly apprciated
Thanks in advance,
Dan
Renault Megane 2004 2.0l 16v Privilige 32400
uncle buck
x 10
Unread post by uncle buck »
It could be that the gear linkages are getting tight when they get warm.
Try greasing them up...pop the cup ends of the rods off the ball joints that they connect to & put a smear of grease in them & reconnect.
Cheers.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
