Noisy clutch when depressed
oscarloco
Unread post by oscarloco »
Hi guys
I have a problem with the clutch of the ZX. The pedal seems a little hard and when I depress the pedal, the clutch mechanism sounds like a Caterpillar engine with the clutch depressed. This sound stops when the clutch is released.
I suspect the throwout bearing. What is your opinion?
Oscar Lopez
'94 ZX 2.0 8v petrol (restoration to its former glory on its way after being neglected by stupid Ex)
x 1240
Unread post by Peter.N. »
If its done a high mileage could be that the fingers have worn through. Or - could be the bearing.
KevMayer
Unread post by KevMayer »
Try cheering it up....
(sorry, couldn't resist)
Cheers, Kev
oscarloco
Peter.N. wrote:If its done a high mileage could be that the fingers have worn through. Or - could be the bearing.
Well the car has about 175,000 miles on it so both are possible.
Oscar Lopez
x 1240
Looks like a gearbox out job then. :cry:
x 8391
KevMayer wrote:Try cheering it up....
:lol: :lol:
Peter.N. wrote:Looks like a gearbox out job then. :cry:
I guess you'll need cheering up now Oscar...
It's not such a bad job to remove the 'box on a ZX.
x 94
Unread post by citronut »
Jim wrote
"It's not such a bad job to remove the 'box on a ZX."
appart from you have to lever the suspension components appart, unlike a depresurised hydraulic citroen
regards malcolm
x 8391
citronut wrote:appart from you have to lever the suspension components appart, unlike a depresurised hydraulic citroen
Ahh yes, I recall well that on a Saxo a while ago. Against that though, you've no hydraulic pipes to get in the way nor a Pressure Regulator to fight with :lol: :lol:
And no LHM reservior to remove in order to get at the gearbox mount :twisted:
'Tis about 50/50 at the end of the day :roll:
x 94
yep spos so,
but i never remove the hydraulic tank when doing a clutch on a xant,
i just undo the two 18mm bolts on top of the box under the chassis rail
regards malcolm
oscarloco
Now I do need some cheering up :?
The noise has gone from a mere "whine" some time ago to a louder sound. Well, looking at the bright side, I will have to learn about gearboxes :shock:
Thanks to everybody for their help and jokes, at least I laughed some :wink:
Oscar Lopez
