Hi Everybody,
A friend has asked me to pose this question as she is not a member. She has a T Reg Xantia (16 valve) and has had a new clutch fitted. The pedal is right at the top and she can't find out how to adjust the auto-clutch mechanism. A friend of mine has had a look and there doesn't seem to be any place to adjust the length. Any ideas gratefully received. Thank you all in advance
Love, Michelle XXX
Xantia Autoclutch mechanism
DickieG
- Monaco's youngest playboy
- x 33
The adjustment is done manually (not auto adjustment) at the gearbox end of the clutch cable where you will find a nut on the end of the cable, undo the nut in order to lower the clutch pedal.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
red_dwarfers
- x 58
You learn something new everyday, I had the idea that it was all automatic adjustment from '96 onwards.DickieG wrote:The adjustment is done manually (not auto adjustment) at the gearbox end of the clutch cable where you will find a nut on the end of the cable, undo the nut in order to lower the clutch pedal.
It would be interesting to know which cars stuck with the manual adjusters or whether it was just the 1.9 that switched over
Kev
'19 C4 Cactus 130 Flair
Xaccers
- x 188
Cassy's a 98 and has manual.
Jenny has auto but I have a feeling it should have been manual but the wrong cable was used.
DIY sphere tool
DIY sphere tool
dnsey
- x 19
flygirl757
LOL Thank you all very very much for your input but now we are confused. I have an L Reg Xantia 1.9TD and it has a nut on the end of the clutch cable for adjustment. My friend's car (the T Reg 16Valve 1.8 as in the original question) has no nut so it surely must be an automatic adjust. Any ideas how to set the adjustment up after a new clutch being fitted?
Love, Michelle
X
Love, Michelle
X
dnsey
- x 19
In theory, the auto adjuster can't be reset, but in practice it can be partially dismantled and unwound after removing the cable - not an easy job though due to the notorious clip holding it to the pedal!
What's the 'throw' of the pedal when measured? I wonder if the problem is really cable adjustment or terminal clutch wear.
