Xantia starting problem
yorkie
Unread post by yorkie »
I have a 98 xantia 1.9 td, which when starting from cold is a pig!! Turns over and over, then eventually goes, throwing white/grey smoke out!
When its warm it starts fine. Glow plugs are fairly new, just flew through an mot emissions check, so am stuck!
M Taylor
Sl4yer
Unread post by Sl4yer »
Sounds like an air leak. No doubt some of the experts will comment soon, but it would help to know which injection pump is fitted (Lucas or Bosch).
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
yorkie
I think its the bosch! Will let you know in daylight
:D
M Taylor
Sl4yer
If it's a Bosch pump, the leak-off pipes will cause starting problems if they admit air. Priming bulbs are also known to fail. On my ZX, the braided pipe from the fuel filter to the pump failed (at a routine service!) and caused some embarrasment once the car had been stood overnight.
2008 Mazda RX-8 231
yorkie
Thanks all. will check tommorrow
:D
M Taylor
x 8412
Do also check the blanking cap on the last injector. It can look Ok but account for many air leaks on the leakoff lines...
If it continues despite a good check for air leaks, come back to us...
yorkie
CitroJim wrote:Do also check the blanking cap on the last injector. It can look Ok but account for many air leaks on the leakoff lines...
the blanking cap,is it just a pop rivet? if it is it looks ok!
M Taylor
Xaccers
x 188
Unread post by Xaccers »
No, should be a short black pipe with no hole in the end coming off the last injector (nearest the lhm resevoir).
Are you sure you got the right glow plugs too, as some are designed to heat then switch off once the engine is running, others (the ones needed) are designed to stay on for longer.
DIY sphere tool
yorkie
the glow plugs have been in for ages, 18 months+ the starting problem only started a month ago. once the car is warm it starts ok!
M Taylor
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
EVEN though the plugs have been in that long I WOULD check them again!
You've basically answered your own question - if she starts fine when warm, I reckon it could well be a plug or two EVEN if they are only 18 months old - Ive known to fit plugs and have them fail 10 months later!!
It wont be much, TD's dont need much to go...
Paul
A very sad...
1994 XM 2.1 d auto
Johnny Cogs
Unread post by Johnny Cogs »
Sorry to drag up an old thread but was aremedy ever found? Was it the glow plugs after all? ta :D
RaceMouse
Unread post by RaceMouse »
Greetings from DK,
I had the same problem with my 1996 2.1 TD Xantia (360Kkm).
I changed to glow plugs (2 of them were dead). That didn't help a bit.
I changed the injectors. That didn't help a bit.
I then repaired a cracked fuel hose between the engine and cabin. Fault gone...
/RaceMouse
06/96 Xantia, 2.1TD Break, 49 mpg avg.
