Handbrake light, stop light come on when I drive over 25 mph
gwb
Unread post by gwb »
Anybody know why the handbrake light (!) and stop warning lights come on as soon as I go over 25 mph.
Fitted new front pads (needed done anyway).
Rear breaks fine.
Renewed DOT4 with DOT4 about 3-4 months ago.
No leaks from pipes or callipers.
Brake reservoir at maximum.
clutch works fine.
Car stops fine.
ABS works fine.
Any ideas anybody?
:D
Citroen C5 2001,1.8I. 107000 miles. Had since new.
falling-out-with-my-car
x 25
Unread post by falling-out-with-my-car »
I do hope you havent put dot 4 brake fluid in the LHM resoviour, if you have it could be very expensive replacing all of the hydraulic seals.
buy yourself a haynes manual it isnt perfect but it will point to where you have gone wrong. 3-4 months with dot 4 brake fluid in the suspension system ouch!!! your hydraulic pump is probably close to failure in which case you will loose your brakes, power steering and suspension quite soon.
only put LHM (green) fluid in the resoviour special hydraulic fluid for citroens.
with the suspension manual height adjuster in between the front seats set to the highest position the orange disc on the float on top of the LHM resoviour tank should be between the two orange lines.
if you have used Dot 4 brake fluid I suspect the whole system needs flushing and being as it was so long ago it is possiable that you have done some considerable damage to the operating seals of the hydraulic system, if not then you are an extreemly lucky individual
regards Nigel.
Last edited by falling-out-with-my-car on 15 Jul 2009, 15:04, edited 2 times in total.
gwb
Hi
It's a C5. It has LDS fluid and the braking or clutch is not on the same system as my hydro
x 8422
Did you adjust the handbrake cables during your work? I'm wondering if the handbrake is being pulled on just enough to active the switch due to maljustment of the handbrake cables?
Also, are you sure it's the handbrake light and not the pad wear indicator? It's very critical that the pad wear wires in the pads are correctly routed to aviod chafing against the disc. If they do chafe, they'll bring the light on as the insulation wears away and it finds an earth from the disc.
x 25
appolagies gwb, I was ill informed by the sounds of it. the handbrake did enter my mind to jim.
regards nigel.
gwb
It's not the handbrake. I changed the front pads, anyway when they wear a orange light comes on. It looks like it has something to do with the speed. When the car is below 25mph it is fine, but as soon as I go over 25 mph it comes on.
x 1941
Unread post by Paul-R »
It sounds like it's a computer fault.
C5s are notorious for strange glitches - mine has habit every few months of popping the tailgate open when I unlock the car or open a door (it's doing it now), but stops doing it after a few days. My C5, since I disconnected the battery 2 weeks ago, only operates the rear dropglasses whenI push the plip for them. The fronts stay exactly where they are.
The first thing to try is disconnecting the battery for 5 or 10 minutes. This can cure some faults. You'll have to reset the clock and radio though.
MikeT
x 232
Unread post by MikeT »
Sorry if this a dumb suggestion but it's nothing to do with the ABS is it? That has a secondary diagnostic that kicks in at about that speed.
gwb
You are correct in what you are saying Mike T. Anyway I found the problem, It was my stop light switch. It was coming out of its bracket.
Thanks everybody for your help.
:D
MikeT
x 232
gwb wrote:You are correct in what you are saying Mike T.
It was a dumb question :oops:
Glad you've found the cause.
mourad
New User
Re: stop light switch
Unread post by mourad »
gwb wrote: 15 Jul 2009, 17:57 You are correct in what you are saying Mike T. Anyway I found the problem, It was my stop light switch. It was coming out of its bracket.
switch is located
light everybody for your help.
:D
Hi gwb.
I m new member and I have the same problem you mentioned could you please tell me where the stop light switch is located please.
