i have had a eye blinding look through the forum to find many posts about similar problems but none with the relay van, so i do need the good help of those who knows loads more than me about this....
basically on the steering column the wiper switch arm has two positions that do nothing and then two that do the slow and fast sweep of the wipers....i would imagine that one of the dead positions should be the interemittent bit...also if i pull the level towards me the jets skwirt but the wipers don't do the usual three sweeps!!!!!
i thought it maybe somelike a relay but don't know where to look as there is no relay map in the hand book (there is one for the fuses!!)
cheers in advance
ant
relay van with no intermittant wipers
falling-out-with-my-car
- x 25
I had a similar problem in my xantia, I don't know if the stalks are similar but I replaced the stalk with a new one and it rectified the problem. a good friend also had the sma e problem with an xantia, and again the stalk was replaced but this time with a second hand one from a breakers.
regards nigel.
regards nigel.
selectsands
relay van relay map needed
cheers nigel will give this a go, but whilst i am on the subject of relays can someone point me in the direction of what and where all the relays are, it would be most helpful....
cheers ant
cheers ant
- x 1055
- x 1055
selectsands
thanks wheeler
i will have a look tom (saturday) on the wiper motor, hopefully i can just replace the relay or are you saying it's a complete motor replace??
cheers
cheers
selectsands
there are two plugs
i had a look and there are two plugs on the underside of the motor, could not see any relays though....i have found relays in two places now, one under the dash new the fuse box and another lot under the bonnet (front and center) in a plastic cover....really wished i knew what they all did...??
