Disposal of old refrigerant
Post your Cit/Peu/Ren air conditioning queries or advice.
x 1940
Unread post by Paul-R »
Just bought a non-starting C5 with a view to breaking for spares.
Is there any way the gifted amateur (ahem) can drain the refrigerant from the A/C or is it a case of sod the ozone layer?
vanny
Unread post by vanny »
A C5 will have R134a refridgerant running through its veins, it is not an ozone depetant! It does however add to the global warming effect.
http://en.wikipedia.org/wiki/1,1,1,2-Tetrafluoroethane
A mobile AC recharge man would probably do it for cash, its not really possible to do by DIY, you need to draw the system down to a vacuum and store the old refridgerant, not to mention seperating the PAG oil.
R134-a will displace air/oxygen as it is dencer than air, and thus kill you by suffocation if your in a small low space.
Its certainly not a good idea to simply crack it in an enclosed area such as a garage.
Xaccers
x 188
Unread post by Xaccers »
Not to mention the risk of frostbite if you get caught in the escaping gas.
DIY sphere tool
