Hi gang problem with c5 break caliper touching alli wheels?
andy c5
Unread post by andy c5 »
On my c5 i have a break caliper on the rear wheel toughing my wheel and its the same on my brouther inlaws car is there a common falt and what may be the cause of this as there is nothing loose?
Many thanks Andy
x 1489
Andy,
It will be the long running saga of corrosion between the calliper and trailing arm causing the caliper to twist. Need to remove the caliper and clean the corrosion off the back till it sits square again. Go careful with the securing bolts - breaking them is not unknown, and removing the remains from the arm can be a right PITA.... :cry:
andy c5
thanks richard nice one :D
