Fitting BX speres to the xantia front end.
- falling-out-with-my-car
- My Cars: Citroen C5 Aircross 8 speed Automatic, Flair Model with far to many toys and nice comfy armchair like leather seats. ha ha Ive just had a conversation with the car. setting everything up verbally
- x 24
I was once told that it was possiable to soften the ride in the front of an Xantia by fitting BX spheres to the front corners.
has anyone tried this or experimented to get a more floaty ride in an Xantia, did you feel sea sick or was it successful?
I have medical issues that make the front end a bit bumpy even with new Xantia sheres and would like to soften the ride if possiable.
any advice would be gratefully recieved.
kind regards Nigel.
kind regards Nigel.
i don't know if you can simply fit bx sphere's, the pipe work would need to match and the pump switched to something that could fill them, might confuse the suspension having different spheres all round
you might want to try heavier wheels, i don't know what wheels yours came with but the heavier alloys add some slop to the cars suspension. which model is yours?
Love my black v6 xant - only one with cream coloured leather too!
- My Cars: C5 V6 Mk1 assainated by wife
Renault Kangoo 1.6 auto, tarted up and remapped
Still missing the Xantia V6
Not missing the AX - Contact:
When I first bought my current Xantia it was fitted with BX spheres as the previous lady owner wanted a smoother ride over the speed humps along her road. It was very floaty but I didn't leave them on long enough to get sea sick.
Lexia ponce
Lexia ponce
i think you could fit BX spheres to a XANT with standerd suspension without any issues, but you could not fit the to a hydractive Xant,
many years ago i fitted GS front spheres to the rear and WOW what a ride,
every time you just looked at the throtle the rear whould hit the bump stop's,
very boat like,
ps.
it sounds to me like your spheres need checking as you said earlyer your not sure if you had re/con spheres fitted,
do you know if they were exchange units, if so they were almost definatly re/coned
regards malcolm
very boat like,
ps.
regards malcolm
- Old-Guy
- My Cars: 2011 Grand C4 Picasso VTR+ 1.6HDi in Kyanos Blue
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - now owned by XanTom
1998 Xantia 2.1 VXD Estate in Mauritius Blue - R.I.P. (terminal tin-worm) - x 17
GSF's old website had a table of spheres available for download, but it's nowhere that I can find on their new site. Fortunately I kept a copy for my own use.
At the risk of upsetting GSF over their copyright, I've made it available at here for the benefit of anyone else who can't find it.
More of my ?help? files at here
(edited) £20 per sphere fitted, sounds to me more like 'conned' than re-conned!
1995 Xantia Estate SX 1.9TD in Vert Vega "The Green Lady" - after 11 years now owned by XanTom
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 70
Of course you can!!
How can a mechanical pump know whats on the struts it just pumps untill the regulator clicks it out...
It DOES make a lovly floaty boat ride! The Taxi customer, I put some on for him about 2 years ago, they lasted from about 150k to 277k !! They are just getting a bit bumpy now!
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 24
Thanks everyone,
for the benefit of those who asked my car is a 1998 xantia 1.9 TD estate S-reg it has the Mk2 front end (grill joined to bonnet).
Has anyone any idea which BX spheres if any could be used to soften the front end ride please? the advice was given a long time ago apparently it wouldnt allow the car to go down to the stops at the front end like the rear.
its a shame the british market had to complain about the floaty ride so we ended up with springs in the front, the roads are bad here in Northants and the xantia seems to dectect every little bump even when the suspension system is in good condition. And before someone brings it up the ride height is pretty accurate, I checked. the book of lies I already have and thats exactly why I joined the forum. I seek truth...lol.
regards Nigel.
regards Nigel.
my R reg MK1 1.9TD estate is more often than not quite a harsh ride, which i know is not corect,
i feel sure now that its due to the H/C linkage's not functioning as freely as they should,
because if i press on and off the front or the rear of the car it feels very soft,
but my daghters N reg 1.9TD hatch is a very plesant ride indeed, and it absourbs the road surface as it should,
so i belive by what you say there is something not quite right regarding you XANT
regards malcolm
regards malcolm
- x 24
malcom,
I get the same result when I push down on the corners the suspension is quite soft, tyre pressures are as spec on drivers door pillar. (unloaded levels). the H/c linkages are all nicely greased with copper grease, the rear linkages have a tendancy to rot away if not kept in check.
The rear middle sphere linkage's are not seized so I am at loggaheads as to what might be causing the bumpy ride, maybe its because I owned a couple of BX's and I expefct more of a quality ride.
if I load up the boot with something heavy the ride improves 100%
why Citroen had to meddle by stiffenning upm the suspensionm on the front beats me.
regards Nigel
regards Nigel
I currently have XM front corner spheres on mine which are softer than Xantia ones but not as soft as BX, might be worth a try.
Lexia ponce
Lexia ponce
i dont think it is possible to say for sure if the H/C linkage's are perfectlly free as they are when brand new without removing them from the car,
i have one i removed from the front of a customers car when i fitted a re/con H/C carridge/linkage i bought from Martin at pleideas for 40 quid,
the carridge i removed i left soaking in old engine oil for a couple of months, when i fished it out it was not any looser, so i spent about an hour squirtting it with duck oil and working it till it was very free, to the point were i could move both the linkage turrets with no efort what so ever,
i plann on fitting this carridge to the front of my car in the near future,
Nigel wrote
"The rear middle sphere linkage's"
there is no linkage attached to the rear middle sphere, well at least on a standerd non/sinker, as all the linkage's are part of the H/C carridge/mountting bracket
my car rides very smooth with weight in the rear also,
this i why i belive these symptons are Hight corrector linkage related
regards malcolm
regards malcolm
- x 24
well we can't all be pro mechanics so if I make a mistake explainning something at least I still know what I mean without somebody being critical of my comments.
the middle rear sphere (accumulator sphere) has a linkage behind it which if I remember links to the Manual height adjuster, if not lubricated regularly this rusts away.
Iv'e broken my glasses so I can't look it up.
Apparently there is only one type of BX sphere suitable for use on the front of the xantia they are not all interchangeable, something to do with the size of valve and gas pressure. with more emphasis on the type of valve used.
no-one seems to know which spheres for which model BX though.
regards Nigel.
regards Nigel.
If you want to look at the sphere table you can get it here
http://uk.geocities.com/perception.av@b ... _table.pdf
You can then compare the volume/pressure/damping and choose a sphere that will suit.
Lexia ponce
Lexia ponce
