1.8 Exhaust, Advice on fitting
lasthope
Unread post by lasthope »
I got a new exhaust (pattern part) for my Xsara Picasso 1.8i petrol 51 reg from ebay here is a pic of it ,need to know on pic does that little pipe I marked red fit into cat, if so the one I got did not so I cut it off, my old one I took off was the same without the little pipe sticking out, just now it seems to be blowing a bit,
x 94
Unread post by citronut »
yes it should fit inside, maybe that end piece from a previous exhaust is still inside the kneck of your cat
regards malcolm
lasthope
lol
cheers mate,looks like i need to stick abit of pipe in now lol
x 94
if you have already cut the bit off the new pipe and i belive this goes to the rear of the cat, only if at rear of cat you can just seperate the joint and smear a nice thick layer of exhaust jointting paste in the bell emd of the cat,
then clap it back together it'll be fine without the short stump
regards malcolm
ps.
you must never use paste in the front of a CAT
lasthope
cheers
i mate allready cut and on car been on a few weeks now,just seems that it is blown from that joint,just seems when both windows are open and you drive along a narrow road sounds funny,but when windows closed and you rev it u hear nout,
