I wondered if dropping the top engine mounting and letting engine down would give more accessablity to the tensioner area.? The bolt holes are there to fit the manual tensioner too, so why didn't cit keep on with that type.?
Greg
Auxilary belt tensioner
Gregg1100
- x 5
90 Kawa EN 500 A1- was running---now dead again
04 Kawa GPZ 500 E10 -alive and well.
54 Fiat Punto 1.2 Dynamic
Old Xantias- 16v 2litre 1997 VSX, 2 x 1993 TD Lx, S2 SX 1.9TD
Old Bx's--3 x 1.9 D, 1x 1.6 Auto, 1 x 1.9 GTi, 1 x 1.9 TZS
- x 8427
There should be no need Greg, at least there was no need on the 2.1TD. Provided you can get to the large bolt (which will be hiding behind the bottom hose), you'll be able to get the tensioner out.
The real tricky one to get at is the lower spring Allen bolt which has to be accessed through a hole in the HP pump casting. A long ball-ended Allen key is the tool of choice here.
