I'm helping a friend with his 2.0l HDi Xantia.
The fronts riding very high on the normal setting, the wheel arch is four and three quarter inches above the the top of the tyre tread.
Everythings fine on the high setting (the arch is six inches above the tyre tread), everythings fine on the low setting.
I've tried setting to normal from low, also I've tried setting to normal from high there's no difference.
I've been under the car (after taking the safety measures) to take a look at the height corrector, the white plastic thingy seems to be intact and I've given the workings a liberal dosing of WD40.
Prior to my friend buying this car, it had the front spheres changed for these Citroen badged silvery/black ones. This was the surprise to me as I've only seen green ones. Could this be the problem?
Ridin' high on silvery/black spheres
- x 94
Xaccers
- x 186
If memory serves, aren't grey sphere's for the C5 and were tested out on some late Xantias?
DIY sphere tool
DIY sphere tool
- x 5648
George
Definatly black with a hint of silver, they sparkle so have some metallic paint. I'll scratch 'em tomorrow to make sure they ain't some custom paint job.myglaren wrote:Yes but could hardly be described as silvery - very drab looking articles they are.Xac wrote:If memory serves, aren't grey sphere's for the C5 and were tested out on some late Xantias?
Actually looks better here than IRL. Mine are very dowdy.
George
Thank's Malcolmcitronut wrote:welcome to this site,
were did the spheres come from, as they are probably re/con but even still the spheres dont usualy affect the hights,
i would say either the linkage is seized solid, or someone has tamperd with the fixed adjustment settings,
regards malcolm
I'm reading some of the cars history now, the front spheres were changed last july. The garage charged the previous owner over fifty quid each, so I presume they were new, apart from the odd colour, they are a bit of an odd shape and don't match the others on the car.
Whilst I was under the car my friend operated the contol linkage and as far as I could tell (it's not easy to see whats going on) the linkage and the springs were moving. The plastic clip was secure in place and no probs with the anti-roll bar.
So how do I tamper with the fixed adjustment settings to return this to normal?
- x 1240
Firstly give the height corrector linkage a few applications of WD40, or anything oily would do. If that doesn't improve it, the height adjustment is effected by rotating the clamp on the anti roll bar that is connected to height control with the engine running. You must have plenty of room under the car when at its lowest suspension setting because it can drop suddenly. Slacken the clamp pinch bolt and rotate the clamp around the bar until the correct height is reached, if the drive shafts are parrellel to the road - that's about right. You only need to move the clamp a small ammount but there is usually a delay before anything happens.
George
Thank's Peter that's very helpful!
Now I don't have access to a ramp nor a pit, but I have super sturdy axel stands what I use on commercial vehicles. So the car would not be falling anywhere, rather the front wheels will rise when the selector is set to low?
Or does it need the weight of the car on the suspension to acheive the lowered position?
- x 1240
- x 94
George
Thank's Peter.N and Citroenut,
I finally got around to fixing this this evening, got the car up on four ramps, an 11mm wobbly socket and a large screwdriver, up it went, down it went, got it just right and alls well!
Another Citroen suspension mystery solved.
Thank's again.
BTW, the strange spheres weren't custom paint and remain a mystery.
Thank's again.
- x 94
i hope it is sorted, but i belive it was still more likely to be sticking linkages,
when you was whatching it move with your freind opperating the lever,
you would probably mainly see the manual hight limkage move, but the auto self leveling bit/turret might not have moved much if at all, as this will only move whilst the suspension is going up and down,
the turret linked to the manual adjuster rod is as said (manual hight adjuster)
the other one is the auto self adjuster linked to the anti roll bar
as i have said before im sure you cant free these of long term whilst attatched to the system
regards malcolm
regards malcolm
- x 1479
Grey LHM spheres discussed here: http://www.frenchcarforum.co.uk/forum/v ... hp?t=27503
£50 each would be about the right price for Citroen Originals.
