Hi.
Can any Xantia Mk2 owners confirm if the cooling fans can operate when the engine is switched off? Mine don't seem to, which, with the current weather, leads to some slightly high temperature readings when restarting.
Thanks,
Xantia cooling fans after switching off
Sl4yer
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
Sid_the_Squid
An interesting question, my 1.8 certainly keeps the cooling fans running for a few seconds after switching off the engine when its very hot, as did my HDi. However my V6 does not. I suspect a fault somewhere, I'd be interested to know if anyone has experienced this before, preferably with a fix.
Gone to the dark side.
Past Citroens
'99 Xantia HDi Exclusive
'99 Xantia 3.0 V6 Exclusive (Green Goblin)
'02 C5 Hdi 110 LX Estate
'98 Xantia 1.8 sx auto with LPG
'00 Xantia Hdi (110) forte
'97 Xantia 1.9D sx
'93 Xantia 1.9D lx (my first) R.I.P
Past Citroens
'97 Xantia 1.9D sx
- x 8386
All mine turn the fans off with the ignition..
One thing I've noticed on my V6 is it only takes a small further increase in temperature before they got to full tilt.
Sid, I wonder if yours work differently as a result of the LPG install in an attempt to keep underbonnet temperatures down when stopped.
My old 205GTi would run it's fans with the ignition off and several times people reported flat batteries as a result...
Xaccers
- x 188
Cassy's fans will kick in if the ignition is off, sometimes a few seconds or so after I've gotten out of the car.
DIY sphere tool
DIY sphere tool
Sid_the_Squid
Jim, AFAIK the car is unaware of the LPG system, certainly in terms of the various ECU's, seeing as this system was hacked in place by Micky Mouse himself I very much doubt he would have had the skill or even inclination to touch the bitron unit.Sid, I wonder if yours work differently as a result of the LPG install in an attempt to keep underbonnet temperatures down when stopped.
Also my totaly unmodified HDi used to run the fans after switch off.
It seems a very controlled thing, the fans only run for about 15 seconds post switch off, and only if they were running before the ignition was switched off, i.e. you had AC on, or the temp was above threashold. Sadly I cant remember if any of my mk1's did this, its been a few years.
Prehapse its only a MK2 thing?
Past Citroens
'97 Xantia 1.9D sx
Past Citroens
'97 Xantia 1.9D sx
leithant
- x 9
Clogzz
- x 40
My Mk I used to, for no good reason, but no longer does.
There was a dodgy crimp connection in the socket into the inner wing near the battery.
The wires from the brown sensor to the Bitron pass through there.
The fans are allowed to stay on at low speed, or turn back on after switching the engine off, for a maximum of 6 minutes, timed by the Bitron.
It’s common for the fans to turn on at low speed on the accessory position when returning to the car with a still hot engine, even after 15 minutes, caused by rising heat.
oscarloco
Thank God, I'm not alone! My ZX does it sometimes (well, most of the time). I hear the fans cick in and if I turn off the car, they shut down. If I start it again in the next 5 minutes or so, they turn on at high speed. So if they are on, I stay in the car until they turn off to avoid unnecessary stress on the radiator (one of the bases is faulty and due to be replaced anytime soon) unless I'm in a hurry.
Oscar Lopez
'94 ZX 2.0 8v petrol (restoration to its former glory on its way after being neglected by stupid Ex)
jmd
dnsey
- x 19
Clogzz
- x 40
Hi Oscar,Thank God, I'm not alone! … they turn on at high speed.
If they do it when the engine is cold, there’s a sensing fault.
One of my wires to the brown sensor measured 3 Ohms I think, not enough to add to the 2K?-plus of the sensor, but still a dodgy connection that sometimes went high to switch to high speed.
Since I bypassed the dodgy crimp connection in the socket into the inner wing near the battery, the fans have never gone to high speed.
That’s in an area where we get 30ºC every day for over 3 months in summer.
Hi dnsey,sticker under the bonnet
No warning sticker because the Xantia fans are inaccessible from the engine room.
The radiator totally fills the front, and removing the fans starts with the removal of the front grill.
