xantia clutches
lexi
x 133
xantia clutches
Unread post by lexi »
As some will know from a previous post I had the deaded clutch clip break. Replaced about 4 weeks ago, So far so good.
However I feel that this new one is straining ........I don`t know really as aint got a car to compare it with. Is there a poundage test for the pedal...I suppose not :lol:
Is there any way of telling that clutch is suss without stripping. I mean it is perfoming on all the usual tests. What causes it to go stiff and need replacing if it is operating ok otherwise.
Easier way out for the meantime may be to try and fab a steel clip that wont break and leave me stuck . That may break the cable?
I don`t mind fitting a new clutch in winter but no time ATM.
Please don`t say it only takes a day..........I know I would be at it all week :shock:
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 94
Unread post by citronut »
isnt it winter in Scotland yet then TEA HE and AKI D NOOOO
if you make a steel clip you might brake other components as well as the cable
i think these back to front pull clutchs are designed so they fail before they slip,
regards malcolm
lexi
x 133
So when clutch is failing it is getting stiffer? Why.
Car is not used much in winter Malcom . In summer it is used only for fishing and travelling up North to fish. Can`t be off the road for any time really. Trafic van is used for work otherwise.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 8406
These clutches are funny Lexi. Heaviness is always a dead give-away but often the plate does not seem that badly worn on inspection.
All I know is that I agree with malcolm on the clip front and that a good 1.9TD clutch is as light as the lightest imaginable feather. Fundamentally, if it's heavy enough to make your foot ache operating it then it's had its day..
lexi
x 133
Thanks .
This is the thing . I m loath to strip . I have a receipt for a clutch done 10k ago but who knows?.
I don`t feel it heavy honestly. It just feels like it is rubbing at clip and a bit of friction. It`s not as light as HDI but you would expect that with an hydaulic MC etc. There is a very slight judder though on take up.
Time will tell.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Xaccers
x 188
Unread post by Xaccers »
Could it be the plastic up things that the arm sits in?
Maybe they weren't changed when the clutch was 10K ago?
DIY sphere tool
x 94
very possible Xac,
but it could also be the cable, i know XANTS dont often eat cables but it has been known
regards malcolm
lexi
x 133
Xac wrote:Could it be the plastic up things that the arm sits in?
You mean the actuating arm under the air filter? Need to look at this . Clutch cable? may get a new one and try it. It seemed free and easy when pushing it through bulkhead for clip location.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 94
Xac means the nylon pivot bushs at the top and bottom of the clutch fork shaft, which need replceing whilst the box is out
regards malcolm
lexi
x 133
citronut wrote:Xac means the nylon pivot bushs at the top and bottom of the clutch fork shaft, which need replceing whilst the box is out
regards malcolm
Ok. keep that in mind when /if box is out.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
dnsey
x 19
Unread post by dnsey »
I had to replace two clutch clips about six months apart, so changed the cable (which seemed to run perfectly well 'off load'), and the result was a smoother, lighter clutch and no more broken clips.
lexi
x 133
dnsey wrote:I had to replace two clutch clips about six months apart, so changed the cable (which seemed to run perfectly well 'off load'), and the result was a smoother, lighter clutch and no more broken clips.
You may be onto something here. It may be worth a try to put a cable and new clip on and see how it goes.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
SLYTZD
Unread post by SLYTZD »
Sorry to be negative but my '96 1.9TD Xantia's cable clutch was always very heavy, broke 2 clips, replaced the cable but made no difference. Still stiff enough for me to often worry that the clip was about to brake if I put the clutch right in. I presumed that the grease had dried up where it pivots on & in the bell housing.
Simon
'96 Xantia Activa in Silver 95,000
uncle buck
x 10
Unread post by uncle buck »
Has anyone given any thought to converting the clutch mechanism to a hydraulic system.
I know from some of the projects detailed on the forum that most of the Xantia owners are very capable people, so would this not be an option?
I'm sure the necessary parts would be available from the breakers.
Just a thought...
Cheers.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
x 94
uncle buck wrote
"Has anyone given any thought to converting the clutch mechanism to a hydraulic system. "
it would be easyer to keep fitting a new clip if/when it was required,
regards malcolm
