Iso connector for cd player ?
Neilsouth
Unread post by Neilsouth »
I'm going to take the pioneer head unit out of the mr2 and put it in the xsara , can i get an iso connector for this to go with the xsara 1.4 ?
It does have some sort of audio control's on the steering wheel of the xsara But i am not bothered about those control's so can i just use the iso connector without some stupid adapter ?
Thankyou
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
Not sure about the Xsara headunits compared to the Xantia but i would imagine the wiring is all in ISO plug format so a pioneer stereo/cd player should be a case of plug n play.As for the steering wheel controls i would be suprised if you cannot aquire an adaptor that will allow you to use the steering wheel controls
Colin
Ross_K
x 110
Unread post by Ross_K »
Neilsouth
admiral51 wrote:Not sure about the Xsara headunits compared to the Xantia but i would imagine the wiring is all in ISO plug format so a pioneer stereo/cd player should be a case of plug n play.As for the steering wheel controls i would be suprised if you cannot aquire an adaptor that will allow you to use the steering wheel controls
Colin
tbh i really don't care for the steering wheel control's , but i'll check halfrauds today for this iso plug.. Thankyou :)
Cheers Ross
Neilsouth
Took the car to an audio specialist i couldn't be bothered to do it all again and i was lucky they said it would connect to the cdplayer perfectly. All they needed to do was add a new faceplate and cage?.
£25 all done , the speakers in the doors had already been updated previously to nice speakers. Sounds lovely , so now all i need to do is get that annoying window sorted :x
