Drivers side window wont go down now i know why , help!
Neilsouth
Unread post by Neilsouth »
Needed a cheap run about and got myself a Citroen Xsara 1.4 LX 8V , however i knew about the drivers side window not working but i thought it was just a fuse.
I took the door panel off and found
Not only was the motor housing missing ( with the magnets in ) , but also the plastic brush housing that goes round the commutator. Can i get these from a scrappy? , i don't need all the rest just these parts :(
And in this heat its terrible lol
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
Hi Neilsouth
Unfortunatley if as i understand Citroen then you will need to but the whole lot :evil: :evil:
The good news is that replacement is straight forward and i would have a good look around your nearest scrap yard for a suitable part much cheaper than the dealers
Colin
Neilsouth
admiral51 wrote:Hi Neilsouth
Colin
I do try to avoid main dealers just like what used to happen with my toyota , they'd charge you an arm and a leg even for just small parts. I'll try a scrappy , cheers :D
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Are my eyes playing tricks or is that a Bloody damm complex winder mechanisem??
TWO RUNNERS? :o The XM and Xantias AND ZX's have a single runner!
Talk about going backwards!
Paul
A very sad...
1994 XM 2.1 d auto
x 5672
My son's wipers failed during heavy rain. It cost him £300 to have a new motor fitted at the dealers.
Mitsubishi Colt.
Citroen single wipers were the best, IMO.
x 1055
Unread post by wheeler »
I cant see anything wrong with that window motor, looks perfectly normal to me. the brushes etc are inside that casing.
Being a xsara my money would be on broken wires inside the door pillar connector, pull the rubber sleeve back & take a look.
A word of warning, when refitting the motor back in make sure you get the correct size rivets as if they are too long they catch the bit that holds the glass on as it goes up & down.
Neilsouth
wheeler wrote:I cant see anything wrong with that window motor, looks perfectly normal to me. the brushes etc are inside that casing.
That's not my motor and picture hence the reason i've put a ring round it that it was missing...
We got the parts and put it on the motor and nothing happens , you can hear the motor make a noise. We felt around abit and the wires are unattached , here are my pics updated from 5mins ago.
Just gets worse and worse , one of the plastic grommets which keep the window in place is broken. The cables are not attached , where do they attach to?
Any full diagrams of this window mechanism ?
What the hell happened to this window device
:shock: :?
Xaccers
x 188
Unread post by Xaccers »
Your best bet is probably to find a good one on a scrap xsara and do a complete swap.
If it fixes to the glass the same way as the Xantia, there should be rubber grommets in the holes of the glass with a split clip (looks a bit like a "R" ) going through it, this then holds onto the peg on the winder unit.
DIY sphere tool
Neilsouth
Looks like i'll have to get the device out then , it sounds as if this is a common thing?
Any idea what causes this to happen
Oh and thankyou
Neilsouth
PART 1 = SUCCESS
Got the motor and runners all out , it looks as if the spindle behind the motor which has the wires has jumped a tooth and caused it to jam. Perhaps someone else in forcing the mirror caused it to break the rest of it.
so tomorrow back to the scrapyard :roll: :lol:
Neilsouth
Now the other side wont go up , doesn't even click!
I'm getting sick and tired of all this crap , i might aswell have gone into debt and kept the mr2 :x
Neilsouth
Which one is the window fuses so i can check?
Neilsouth
Fixed it , gave the window motor a tap and it worked
x 5672
BFH, works every time :D
Neilsouth
haha
