On Saturday Richard (DickieG) and I changed the U-shaped suspension buffer (p/n 96132370) that sits above the top engine mount, under the diesel hand primer pump. That suspension buffer sits on top of a conical shaped 'spacer' (p/n 1827.27), which in turn sits on top of the actual mount, I think.
When holding the thread of the spacer we found it very easy to wiggle it around. Should it feel so 'sloppy', suggesting the rubber mount itself is worn, or should it be firm?
Bob
Xantia 1.9TD top engine mount
firstrebel
Robert Isaac
1997 Xantia 1.9TD SX Estate. 152000 miles
1995 Volvo 855 T5 Auto - Chipped. 186000 miles
citroenxm
- Fallen Hero
- x 70
- x 8412
You mean the rubber mount (the bit with the thread poking out of the top) wobbled around like a good 'un?
Pretty normal in my experience. It's a fluid filled mount and provided it is not split and spilled the fluid inside then it's pretty much OK. Do look for preishing cracks in it though..
The reason for the two buffers either side of it is to control movement simply because the mount is so soft.
If it's all moving excessively then that points fairly and squarely to a lower donut mount on its way out, especially if it has at some point be over-stressed or is contaminated with oil.
I'm of the belief that the top mount is in part responsible for the lovely smoothness of the 1.9TD. Without it being so soft the whole thing may well be much harsher than it is
citroenxm
- Fallen Hero
- x 70
Ah, it was the "Suspension" word that put me off, not using the "Top Engine Mount" words lost me..
Agreed, this is a rather sloppy mount ON ITS OWN, and should be limited by the two rubber end stops either side..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
XantiaMan
- x 18
This mount, or should i say the buffers on the mount decided to split on my old TD. Because of this, it started premature failure of the lower mount too. New buffer section from Citroen sorted it, it also need a little bend due to the wear area on the engine mount bracket.
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
2017 Fiesta ST
firstrebel
Sorry about the 'suspension' red herring. The two rubber buffers each side of the U bracket were well knackered; one side was hanging off. So I might get a new donut in case.
What size socket will get the conical metal 'spacer' off, or is there a better way than a socket.
Bob
Bob
Robert Isaac
