back suspension still at the low when at normal height
xantia2.1td
i have a citroen xantia 2.1 td vsx r-reg mk1 and when the car is a usual ride height the back suspension is still low and do you know what is the problem and how can i solve it
- x 8415
Hi and welcome to the forum
I suspect very much that the white plastic link has become detetched between the rear anti-roll bar and the height corrector. A common enough occurrance.
This is normally because the height corrector mechanism has seized up of become stiff.
Jack up and SUPPORT VERY SECURELY (these cars can kill if the suspension collapses on you) and have a look at the height corrector link. If it is off, don't reattach it until you have given the height corrector some TLC. Douse it is WD40 and exercise it before greasing it. I find spray grease works well.
If the corrector remains stiff in operation, you may need to remove it and give it a real good overhaul.
There are laods of posts on here concerning this issue. A seach will give some useful threads.
xantia2.1td
have u got a pic of where it is located on the car
Sid_the_Squid
Like Jim says its reasonably common for rear height to have the little white 'clippy thing' become broken or detached from the roll bar, or correctors to be come corroded and stick.
Check the condition of the corrector, its just behind the spare wheel, looks something like this
That image seems to be taken from lying directly underneath the height corrector
Note thats not my picture found via the magic of google.
Link the the picture, it has captions in the highlighted areas.
http://www.flickr.com/photos/deiz92/429467953/
Hope this helps.
Oh and Hi welcome to the forum.
Hope this helps.
Gone to the dark side.
Past Citroens
'99 Xantia HDi Exclusive
'99 Xantia 3.0 V6 Exclusive (Green Goblin)
'02 C5 Hdi 110 LX Estate
'98 Xantia 1.8 sx auto with LPG
'00 Xantia Hdi (110) forte
'97 Xantia 1.9D sx
'93 Xantia 1.9D lx (my first) R.I.P
Past Citroens
'97 Xantia 1.9D sx
- x 94
as has already been said appart from its as Jim said its the H/C exturnal linkage's which become seized/stiff, as the actual H/C its self very seldom gives any problems,
Martin at PLEAIDES has in the past sold me just the H/C carridge/mountting/bracket before at a very resonable price, very quick service to boot,
if you go this route studdy very closely how the H/C is attatched to the mechanisum, it is fiddly but quite simple, but also can and will try to go in the wrong way
regards malcolm
regards malcolm
citroenxm
- Fallen Hero
- x 70
