205 1.8 Dturbo front hub
mark21td
Unread post by mark21td »
Bit like the 405 hub post on here, is there another pug that uses this hub as the wheel bearing has compleatly colapesed !
99 406 LX HDI 90 estate
99 C250TD sport estate
01 306 HDI 90 meridian estate
Brew my own biodiesel
http://www.shorewasteoil.xtreemhost.com/" onclick="window.open(this.href);return false;
x 8448
Hi Mark,
It's a bit of a distant memory now as it's a while since I've been into a 205 but I believe the hubs on your DTurbo are the same as the 205GTi 1.6 but not the same as on an N/A 205 D or any of the little petrols.. I seem to recall a significant difference.
I reckon, but don't take it as gospel, but 309 hubs may be the same.
You should be able to recover the hub but you'll need a hydraulic press to remove the remains of the old bearing. They really do get tight in there. Is there another reason why the hub is scrap?
